Raspberry Pi Forum SSD for Pi-Top?
  • Replies 16 replies
  • Answers 6 answers
  • Subscribers 705 subscribers
  • Views 4103 views
  • pi-top laptop
  • ssd
SSD for Pi-Top?
jayrabe
jayrabe over 8 years ago
I have a Pi Desktop with SSD and like it a lot, but now I see the Pi-Top laptop that is even better in having access to breadboarding.
But, is there room/support for adding an SSD to the Pi-Top?
Jay
    0 e14 Contributor over 8 years ago in reply to beacon_dave
    Okay, now I see it.  Apologies.  Your pic seems to be from the Magpi review.
    Clearly, the adafruit kits or the put-it-together blog is out of date.  Even the Hub/Pi interfacing technique has changed in pi-top v2, leaving a way to cleanly expose the RPi's USB & Ethernet ports to the rear.
    Agreed.  There are some short stick USB SSDs around but I do not like them sticking out the back of the laptop.  I prefer your idea of a short USB cable connected with a 90-degree plug but how to mount an SSD inside the case on the rail is a challenge.
    I like the X850 mSATA SSD storage expansion board but as you pointed out, it's probably too high.
  • beacon_dave
    0 beacon_dave over 8 years ago in reply to e14 Contributor
    Just make a mounting bracket that sits between the SSD drive and the mounting rails of the Pi-Top. There are probably already designs for such things on Thingiverse.
    Making a mounting bracket may not be necessary.  There are mSATA/USB stackable boards for the Raspberry Pi.  Here are 2 examples from https://www.startech.com/Search?search_term=msata+raspberryimage
    Obviously, you can't stack inside the pi-top enclosure but the screws seem to line up with the Raspberry Pi which mounts magnetically on the rails.  It would appear that the mSATA cards could mount the same way.  I just need to go to a store which has a display pi-top model and verify that there is enough left over area for an extra board - should be - and an mSATA card can mount the same way.  Maybe, I can talk them into letting me try it out with the display model before purchasing.
    Make sense?
    Hopefully, there is enough power running on the battery as well as off a wall socket.  Running off a battery for an SSD (non-mechanical drive) should be okay.  Other opinions?
  • beacon_dave
    May be of interest - Felix has just done a video of a teardown of the new Pi-Top:
    sudo Sergeant 15: Pi-Top Teardown
    Before relying on the pi-top internal HUB USB, you might want to see the following discussion: https://support.pi-top.com/en/support/discussions/topics/24000005396
    Also, I am personally finding the pi-top service staff in need of more training and experience.  A lot of tech questions need consulting with "China engineering".  Also, there is a lack of technical specifications about the internal HUB, in general.  I get the feeling that this is one of those "$, trial, and error" products.  Not giving up; just a note of caution.
