Raspberry Pi Forum HIFIBERRY DIGI I/O DARKICE: ALSADSPSOURCE.CPP:265: INPUT/OUTPUT ERROR [0]
  • Replies 14 replies
  • Subscribers 706 subscribers
  • Views 3766 views
  • rasberry_pi_3_b_plus
benip
benip over 8 years ago
Hello, I have this error message
after setting up my hifiberry digi+ i/o board with darkice and a PI3:
Using config file: /etc/darkice.cfg
Using ALSA DSP input device: plughw:0,0
Using POSIX real-time scheduling, priority 4
Using aacplus codec
DarkIce: AlsaDspSource.cpp:265: Input/output error [0]
what does it mean?  How to solve the problem ?
I followed this configuration
for the install of the hifiberry board:
sudo nano /boot/config.txt
dtoverlay = hifiberry-digi
# Enable audio (loads snd_bcm2835)
dtoverlay=hifiberry-digi
after restart, i have :
**** Liste des Périphériques Matériels PLAYBACK ****
carte 0: sndrpihifiberry [snd_rpi_hifiberry_digi], périphérique 0: HifiBerry Digi HiFi wm8804-spdif-0 []
Sous-périphériques: 1/1
Sous-périphérique #0: subdevice #0
sudo nano /etc/asound.conf
pcm.!default {
type hw card 0
ctl.!default {
type hw card 0
My config with darkice is :
# this section describes general aspects of the live streaming session
[general]
duration = 0 # duration of encoding, in seconds. 0 means forever
bufferSecs = 5 # size of internal slip buffer, in seconds
reconnect = yes # reconnect to the server(s) if disconnected
# this section describes the audio input that will be streamed
[input]
# device = /dev/dsp # OSS DSP soundcard device for the audio input
device = plughw:0,0 # OSS DSP soundcard device for the audio input
sampleRate = 44100 # sample rate in Hz. try 11025, 22050 or 44100
bitsPerSample = 16 # bits per sample. try 16
channel = 2 # channels. 1 = mono, 2 = stereo
# this section describes a streaming connection to a ShoutCast server
# there may be up to 8 of these sections, named [shoutcast-0] ... [shoutcast-7]
# these can be mixed with [icecast-x] and [icecast2-x] sections
[shoutcast-0]
bitrateMode = vbr # average bit rate
format = mp3 # format of the stream: ogg vorbis
bitrate = 88 # bitrate of the stream sent to the server
quality = 0.5 # encoding quality
server = myip
# host name of the server
port = myport # source port of the ShoutCast server, usually 8001
password = mypass # source password to the ShoutCast server
name =  test darkice
# name of the stream
url = http://www.yourserver.com
# URL related to the stream
genre = my own # genre of the stream
public = no # advertise this stream?
irc = irc.yourserver.com
# IRC info related to the stream
aim = aim here # AIM info related to the stream
icq = I see you too
# ICQ info related to the stream
Thanks for your answer
best regards
Ben
  • jomoenginer
    0 jomoenginer over 8 years ago in reply to benip
    That is a bummer.
    Have you sent a message to the Darkice folks?
    So regarding your use of plughw, I guess that is a slave device?  Does the HiFiBerry show as a USB Audio device?
    If you have not done so already, you might want to check that HiFiBerry is working properly.
    This seems like a way to check the device with 'arecord'
    https://sites.google.com/site/glyman3home/raspi-streaming-to-broadcastify
    These links might be of assistance.
    https://support.hifiberry.com/hc/en-us/community/posts/201494532-Use-of-ALSA
    https://github.com/raspberrypi/linux/issues/1004#issuecomment-133852133
    See the post for : BBUK commented on Aug 23, 2015
  • benip
    0 benip over 8 years ago in reply to jomoenginer
    Hi jon,
    yes I sent a message on the forum darkice:
    https://github.com/rafael2k/darkice/issues/139
    I do not have an answer for the moment.
    The hifiberry digi+ i/o is not a USB board
    I can listen to sound with this configuration but i can't record...
    I continue to search
    Thanks for your links
  • jomoenginer
    That is interesting. I thought 'plughw' was associated with a USB device.
    Have you tried " hw1,0" instead?
  • benip
    Hi jon,
    I think plughw is rather associated with the hardware part in general.
    yes I tried with 1.0 but it doesn't work
