Raspberry Pi Forum HIFIBERRY DIGI I/O DARKICE: ALSADSPSOURCE.CPP:265: INPUT/OUTPUT ERROR [0]
  • Replies 14 replies
  • Subscribers 706 subscribers
  • Views 3830 views
  • rasberry_pi_3_b_plus
benip
benip over 8 years ago
Hello, I have this error message
after setting up my hifiberry digi+ i/o board with darkice and a PI3:
Using config file: /etc/darkice.cfg
Using ALSA DSP input device: plughw:0,0
Using POSIX real-time scheduling, priority 4
Using aacplus codec
DarkIce: AlsaDspSource.cpp:265: Input/output error [0]
what does it mean?  How to solve the problem ?
I followed this configuration
for the install of the hifiberry board:
sudo nano /boot/config.txt
dtoverlay = hifiberry-digi
# Enable audio (loads snd_bcm2835)
dtoverlay=hifiberry-digi
after restart, i have :
**** Liste des Périphériques Matériels PLAYBACK ****
carte 0: sndrpihifiberry [snd_rpi_hifiberry_digi], périphérique 0: HifiBerry Digi HiFi wm8804-spdif-0 []
Sous-périphériques: 1/1
Sous-périphérique #0: subdevice #0
sudo nano /etc/asound.conf
pcm.!default {
type hw card 0
ctl.!default {
type hw card 0
My config with darkice is :
# this section describes general aspects of the live streaming session
[general]
duration = 0 # duration of encoding, in seconds. 0 means forever
bufferSecs = 5 # size of internal slip buffer, in seconds
reconnect = yes # reconnect to the server(s) if disconnected
# this section describes the audio input that will be streamed
[input]
# device = /dev/dsp # OSS DSP soundcard device for the audio input
device = plughw:0,0 # OSS DSP soundcard device for the audio input
sampleRate = 44100 # sample rate in Hz. try 11025, 22050 or 44100
bitsPerSample = 16 # bits per sample. try 16
channel = 2 # channels. 1 = mono, 2 = stereo
# this section describes a streaming connection to a ShoutCast server
# there may be up to 8 of these sections, named [shoutcast-0] ... [shoutcast-7]
# these can be mixed with [icecast-x] and [icecast2-x] sections
[shoutcast-0]
bitrateMode = vbr # average bit rate
format = mp3 # format of the stream: ogg vorbis
bitrate = 88 # bitrate of the stream sent to the server
quality = 0.5 # encoding quality
server = myip
# host name of the server
port = myport # source port of the ShoutCast server, usually 8001
password = mypass # source password to the ShoutCast server
name =  test darkice
# name of the stream
url = http://www.yourserver.com
# URL related to the stream
genre = my own # genre of the stream
public = no # advertise this stream?
irc = irc.yourserver.com
# IRC info related to the stream
aim = aim here # AIM info related to the stream
icq = I see you too
# ICQ info related to the stream
Thanks for your answer
best regards
Ben
    0 shabaz over 8 years ago
    Hi Ben,
    I don't know the answer, but maybe that config file needs the line containing plughw:0.0 changed to hw:0,0 or list the contents of /dev to see if your sound card is there, and use that instead, i.e. set it to /dev/xyz
    These are just guesses I'm afraid, I don't own this hifiberry card nor used darkice.
  • jomoenginer
    0 jomoenginer over 8 years ago
    There is an older post with a similar error.  You may try looking at this to see if it is the same as the error you are seeing.
    https://www.element14.com/community/thread/32651/l/darkice-alsadspsourcecpp265-inputoutput-error-0?displayFullThread=true
    Also, in Actions menu of the forum editor there is a ">>" "Syntax Highlighting" you can click on to get a list of code formats to post your code in.  This will make reading the code you post easier to read.
  • benip
    0 benip over 8 years ago in reply to shabaz
    Hi shabaz,
    thanks for our answer. i try to change plughw 0,0 with hw 0,0 and i have the same problem
  • benip
    0 benip over 8 years ago in reply to jomoenginer
    Thanks for your answer jon.
    i saw this post :
    but I don't understand how the problem had been solved ...
    he's talking about a script to execute ?
    how to go in "" "Syntax Highlighting" with my RPI3 ?
  • jomoenginer
    0 jomoenginer over 8 years ago in reply to benip
    The reference to "Syntax Highlighting" was related to when you post code on this forum; it is not on the Raspberry Pi.
    On your Raspberry Pi, try running 'dmesg' and see if there are any messages related to the hifiberry.  Perhaps a different device instances is being created that is not being picked up.
  • benip
    Hi Jon,
    Thanks. When i excecute "dmesg" i have :
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Linux version 4.9.35-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1014 SMP Fri Jun 30 14:47:43 BST 2017
    [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
    [    0.000000] CPU: div instructions available: patching division code
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] OF: fdt:Machine model: Raspberry Pi 3 Model B Rev 1.2
    [    0.000000] cma: Reserved 8 MiB at 0x3a800000
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] On node 0 totalpages: 241664
    [    0.000000] free_area_init_node: node 0, pgdat 80c6ee40, node_mem_map b9faa000
    [    0.000000]   Normal zone: 2124 pages used for memmap
    [    0.000000]   Normal zone: 0 pages reserved
    [    0.000000]   Normal zone: 241664 pages, LIFO batch:31
    [    0.000000] percpu: Embedded 14 pages/cpu @b9f64000 s25600 r8192 d23552 u57344
    [    0.000000] pcpu-alloc: s25600 r8192 d23552 u57344 alloc=14*4096
    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 239540
    [    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=1024 bcm2708_fb.fbheight=768 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=7c397252-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
    [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Memory: 936296K/966656K available (7168K kernel code, 484K rwdata, 2012K rodata, 1024K init, 778K bss, 22168K reserved, 8192K cma-reserved)
    [    0.000000] Virtual kernel memory layout:
        vector  : 0xffff0000 - 0xffff1000   (   4 kB)
        fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
        vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
        lowmem  : 0x80000000 - 0xbb000000   ( 944 MB)
        modules : 0x7f000000 - 0x80000000   (  16 MB)
          .text : 0x80008000 - 0x80800000   (8160 kB)
          .init : 0x80b00000 - 0x80c00000   (1024 kB)
          .data : 0x80c00000 - 0x80c79014   ( 485 kB)
           .bss : 0x80c7b000 - 0x80d3da64   ( 779 kB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] Hierarchical RCU implementation.
    [    0.000000] Build-time adjustment of leaf fanout to 32.
    [    0.000000] NR_IRQS:16 nr_irqs:16 16
    [    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
    [    0.000009] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
    [    0.000021] Switching to timer-based delay loop, resolution 52ns
    [    0.000328] Console: colour dummy device 80x30
    [    0.000348] console [tty1] enabled
    [    0.000374] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
    [    0.000391] pid_max: default: 32768 minimum: 301
    [    0.000729] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.000739] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.001729] Disabling cpuset control group subsystem
    [    0.001887] CPU: Testing write buffer coherency: ok
    [    0.001929] ftrace: allocating 22390 entries in 66 pages
    [    0.053968] CPU0: update cpu_capacity 1024
    [    0.053986] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.054058] Setting up static identity map for 0x100000 - 0x100034
    [    0.056282] CPU1: update cpu_capacity 1024
    [    0.056290] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [    0.057005] CPU2: update cpu_capacity 1024
    [    0.057012] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
    [    0.057678] CPU3: update cpu_capacity 1024
    [    0.057684] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
    [    0.057767] Brought up 4 CPUs
    [    0.057777] SMP: Total of 4 processors activated (153.60 BogoMIPS).
    [    0.057781] CPU: All CPU(s) started in HYP mode.
    [    0.057785] CPU: Virtualization extensions available.
    [    0.058583] devtmpfs: initialized
    [    0.069934] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
    [    0.070205] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.070222] futex hash table entries: 1024 (order: 4, 65536 bytes)
    [    0.070756] pinctrl core: initialized pinctrl subsystem
    [    0.071656] NET: Registered protocol family 16
    [    0.074035] DMA: preallocated 1024 KiB pool for atomic coherent allocations
    [    0.083028] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.083035] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.083186] Serial: AMBA PL011 UART driver
    [    0.085047] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
    [    0.085563] uart-pl011 3f201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
    [    0.154532] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb80f000, dmachans=0x1
    [    0.156357] SCSI subsystem initialized
    [    0.156514] usbcore: registered new interface driver usbfs
    [    0.156589] usbcore: registered new interface driver hub
    [    0.156685] usbcore: registered new device driver usb
    [    0.163505] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-07-03 14:16
    [    0.165005] clocksource: Switched to clocksource arch_sys_counter
    [    0.211818] VFS: Disk quotas dquot_6.6.0
    [    0.211895] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    0.212094] FS-Cache: Loaded
    [    0.212337] CacheFiles: Loaded
    [    0.224503] NET: Registered protocol family 2
    [    0.225413] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.225522] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.225706] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.225793] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    0.225834] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    0.226039] NET: Registered protocol family 1
    [    0.226447] RPC: Registered named UNIX socket transport module.
    [    0.226452] RPC: Registered udp transport module.
    [    0.226457] RPC: Registered tcp transport module.
    [    0.226461] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.227538] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
    [    0.229819] workingset: timestamp_bits=14 max_order=18 bucket_order=4
    [    0.245987] FS-Cache: Netfs 'nfs' registered for caching
    [    0.246960] NFS: Registering the id_resolver key type
    [    0.246991] Key type id_resolver registered
    [    0.246995] Key type id_legacy registered
    [    0.249408] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
    [    0.249512] io scheduler noop registered
    [    0.249518] io scheduler deadline registered (default)
    [    0.249774] io scheduler cfq registered
    [    0.255468] BCM2708FB: allocated DMA memory fa910000
    [    0.255492] BCM2708FB: allocated DMA channel 0 @ bb80f000
    [    0.277956] Console: switching to colour frame buffer device 128x48
    [    0.292140] bcm2835-rng 3f104000.rng: hwrng registered
    [    0.292259] vc-cma: Videocore CMA driver
    [    0.292265] vc-cma: vc_cma_base      = 0x00000000
    [    0.292270] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
    [    0.292276] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
    [    0.292473] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
    [    0.307804] brd: module loaded
    [    0.316673] loop: module loaded
    [    0.316684] Loading iSCSI transport class v2.0-870.
    [    0.317202] usbcore: registered new interface driver smsc95xx
    [    0.317217] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
    [    0.545265] Core Release: 2.80a
    [    0.545273] Setting default values for core params
    [    0.545304] Finished setting default values for core params
    [    0.745688] Using Buffer DMA mode
    [    0.745694] Periodic Transfer Interrupt Enhancement - disabled
    [    0.745698] Multiprocessor Interrupt Enhancement - disabled
    [    0.745704] OTG VER PARAM: 0, OTG VER FLAG: 0
    [    0.745714] Dedicated Tx FIFOs mode
    [    0.746054] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xba904000 dma = 0xfa904000 len=9024
    [    0.746079] FIQ FSM acceleration enabled for :
    Non-periodic Split Transactions
    Periodic Split Transactions
    High-Speed Isochronous Endpoints
    Interrupt/Control Split Transaction hack enabled
    [    0.746085] dwc_otg: Microframe scheduler enabled
    [    0.746127] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x8058ef90
    [    0.746136] WARN::hcd_init_fiq:460: FIQ ASM at 0x8058f300 length 36
    [    0.746146] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb87a000
    [    0.746203] dwc_otg 3f980000.usb: DWC OTG Controller
    [    0.746237] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
    [    0.746267] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
    [    0.746313] Init: Port Power? op_state=1
    [    0.746318] Init: Power Port (0)
    [    0.746513] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [    0.746523] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    0.746531] usb usb1: Product: DWC OTG Controller
    [    0.746539] usb usb1: Manufacturer: Linux 4.9.35-v7+ dwc_otg_hcd
    [    0.746547] usb usb1: SerialNumber: 3f980000.usb
    [    0.747373] hub 1-0:1.0: USB hub found
    [    0.747418] hub 1-0:1.0: 1 port detected
    [    0.748097] dwc_otg: FIQ enabled
    [    0.748101] dwc_otg: NAK holdoff enabled
    [    0.748105] dwc_otg: FIQ split-transaction FSM enabled
    [    0.748120] Module dwc_common_port init
    [    0.748357] usbcore: registered new interface driver usb-storage
    [    0.748579] mousedev: PS/2 mouse device common for all mice
    [    0.749514] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
    [    0.749789] bcm2835-cpufreq: min=600000 max=1200000
    [    0.750175] sdhci: Secure Digital Host Controller Interface driver
    [    0.750180] sdhci: Copyright(c) Pierre Ossman
    [    0.750452] sdhost-bcm2835 3f202000.sdhost: could not get clk, deferring probe
    [    0.752622] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
    [    0.752721] sdhci-pltfm: SDHCI platform and OF driver helper
    [    0.755970] ledtrig-cpu: registered to indicate activity on CPUs
    [    0.756155] hidraw: raw HID events driver (C) Jiri Kosina
    [    0.756335] usbcore: registered new interface driver usbhid
    [    0.756339] usbhid: USB HID core driver
    [    0.757106] vchiq: vchiq_init_state: slot_zero = 0xba980000, is_master = 0
    [    0.759141] Initializing XFRM netlink socket
    [    0.759163] NET: Registered protocol family 17
    [    0.759284] Key type dns_resolver registered
    [    0.759795] Registering SWP/SWPB emulation handler
    [    0.760485] registered taskstats version 1
    [    0.760827] vc-sm: Videocore shared memory driver
    [    0.760836] [vc_sm_connected_init]: start
    [    0.767636] [vc_sm_connected_init]: end - returning 0
    [    0.773521] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
    [    0.775108] sdhost: log_buf @ ba907000 (fa907000)
    [    0.855038] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
    [    0.857255] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
    [    0.857263] mmc-bcm2835 3f300000.mmc: DMA channel allocated
    [    0.915154] of_cfs_init
    [    0.915256] of_cfs_init: OK
    [    0.915749] Waiting for root device PARTUUID=7c397252-02...
    [    0.926715] mmc0: host does not support reading read-only switch, assuming write-enable
    [    0.928679] mmc0: Problem switching card into high-speed mode!
    [    0.928815] mmc0: new SDHC card at address 0001
    [    0.929497] mmcblk0: mmc0:0001 ASTC 14.6 GiB
    [    0.931743]  mmcblk0: p1 p2
    [    0.936140] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    [    0.937687] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    0.939234] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    [    0.942014] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    [    0.965122] Indeed it is in host mode hprt0 = 00021501
    [    1.032660] random: fast init done
    [    1.054918] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    1.054964] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    1.056755] devtmpfs: mounted
    [    1.058573] Freeing unused kernel memory: 1024K (80b00000 - 80c00000)
    [    1.092900] mmc1: new high speed SDIO card at address 0001
    [    1.165060] usb 1-1: new high-speed USB device number 2 using dwc_otg
    [    1.165197] Indeed it is in host mode hprt0 = 00001101
    [    1.395341] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
    [    1.395355] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [    1.396191] hub 1-1:1.0: USB hub found
    [    1.396289] hub 1-1:1.0: 5 ports detected
    [    1.561794] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
    [    1.562135] systemd[1]: Detected architecture 'arm'.
    [    1.715061] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
    [    1.749037] NET: Registered protocol family 10
    [    1.750435] systemd[1]: Inserted module 'ipv6'
    [    1.752734] systemd[1]: Set hostname to <raspberrypi>.
    [    1.752883] systemd[1]: Initializing machine ID from random generator.
    [    1.753082] systemd[1]: Installed transient /etc/machine-id file.
    [    1.845425] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
    [    1.845439] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
    [    1.848366] smsc95xx v1.0.5
    [    1.938928] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:13:b1:7c
    [    2.035068] usb 1-1.4: new low-speed USB device number 4 using dwc_otg
    [    2.171068] usb 1-1.4: New USB device found, idVendor=045e, idProduct=0040
    [    2.171082] usb 1-1.4: New USB device strings: Mfr=1, Product=3, SerialNumber=0
    [    2.171090] usb 1-1.4: Product: Microsoft 3-Button Mouse with IntelliEye(TM)
    [    2.171098] usb 1-1.4: Manufacturer: Microsoft
    [    2.176785] input: Microsoft Microsoft 3-Button Mouse with IntelliEye(TM) as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:045E:0040.0001/input/input0
    [    2.177205] hid-generic 0003:045E:0040.0001: input,hidraw0: USB HID v1.10 Mouse [Microsoft Microsoft 3-Button Mouse with IntelliEye(TM)] on usb-3f980000.usb-1.4/input0
    [    2.275061] usb 1-1.5: new low-speed USB device number 5 using dwc_otg
    [    2.402643] systemd[1]: Cannot add dependency job for unit regenerate_ssh_host_keys.service, ignoring: Unit regenerate_ssh_host_keys.service failed to load: No such file or directory.
    [    2.406331] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
    [    2.406693] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [    2.406767] systemd[1]: Starting Remote File Systems (Pre).
    [    2.435817] usb 1-1.5: New USB device found, idVendor=03f0, idProduct=0024
    [    2.435830] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
    [    2.435838] usb 1-1.5: Product: HP Basic USB Keyboard
    [    2.435846] usb 1-1.5: Manufacturer: CHICONY
    [    2.452108] input: CHICONY HP Basic USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.5/1-1.5:1.0/0003:03F0:0024.0002/input/input1
    [    2.516086] hid-generic 0003:03F0:0024.0002: input,hidraw1: USB HID v1.10 Keyboard [CHICONY HP Basic USB Keyboard] on usb-3f980000.usb-1.5/input0
    [    2.634867] fuse init (API version 7.26)
    [    2.716713] i2c /dev entries driver
    [    2.996827] systemd-udevd[142]: starting version 215
    [    3.900461] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [    3.938598] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
    [    4.197041] wm8804 1-003b: revision E
    [    4.221150] snd-hifiberry-digi soc:sound: wm8804-spdif <-> 3f203000.i2s mapping ok
    [    4.490542] usbcore: registered new interface driver brcmfmac
    [    4.694688] brcmfmac: Firmware version = wl0: Aug  7 2017 00:46:29 version 7.45.41.46 (r666254 CY) FWID 01-f8a78378
    [    5.568025] systemd-journald[135]: Received request to flush runtime journal from PID 1
    [    8.154514] uart-pl011 3f201000.serial: no DMA platform data
    [    9.067878] Adding 102396k swap on /var/swap.  Priority:-1 extents:2 across:167932k SSFS
    [    9.216344] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
    [   10.891067] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
    [   12.660470] Bluetooth: Core ver 2.22
    [   12.660544] NET: Registered protocol family 31
    [   12.660550] Bluetooth: HCI device and connection manager initialized
    [   12.660568] Bluetooth: HCI socket layer initialized
    [   12.660581] Bluetooth: L2CAP socket layer initialized
    [   12.660616] Bluetooth: SCO socket layer initialized
    [   12.684256] Bluetooth: HCI UART driver ver 2.3
    [   12.684267] Bluetooth: HCI UART protocol H4 registered
    [   12.684273] Bluetooth: HCI UART protocol Three-wire (H5) registered
    [   12.684436] Bluetooth: HCI UART protocol Broadcom registered
    [   13.127293] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   13.127300] Bluetooth: BNEP filters: protocol multicast
    [   13.127310] Bluetooth: BNEP socket layer initialized
    [   24.179416] bcm2835-dma 3f007000.dma: DMA transfer could not be terminated
    [   24.182919] bcm2835-dma 3f007000.dma: DMA transfer could not be terminated
    [   35.985690] random: crng init done
  • jomoenginer
    it appears your HiFiBerry device is seen:
    However, is this the correct driver you want to attach to the HiFiBerry?
    Looking at the following instructions for the HiFiBerry, driver snd-soc-wm8804 should be blacklisted .
    https://www.hifiberry.com/build/documentation/hifiberry-software-configuration/
    You can use 'lsmod' to list the drivers that are loaded on your Pi and see if the correct driver is installed.
    Also, you can run the following and see if you get any data for the device:
    aplay -l
  • benip
    Hi jon,
    I tested the method you sent me. it don't work at home.
    when i do : sudo nano /etc/modprobe.d/raspi-blacklist.conf
    i have nothing
    and when i do : sudo nano /etc/modules with :
    DIGI AND DIGI+
    snd_soc_bcm2708 bcm2708_dmaengine snd_soc_hifiberry_digi
    after reboot i have the same error...
  • jomoenginer
    benip  wrote:
    Hi jon,
    It's not my method, it's what is posted on hifiberry site.
    Just out of curiosity, did you get any response from the HiFiBerry site?
  • benip
    Hi jon,
    No, I haven't had an answer yet about the HIFIBerry site
