Raspberry Pi Forum Can I burn Windows ISO to Pi?
  • Replies 7 replies
  • Answers 2 answers
  • Subscribers 709 subscribers
  • Views 2284 views
gnatys27
gnatys27 over 8 years ago
Most of Pi boards are powered by Linux, I am wondering it is OK to write Windows iso to Pi.
  • jomoenginer
    0 jomoenginer over 8 years ago
    Microsoft came up with an Windows IoT Core that can run on a Raspberry Pi but it is not a full Windows type desktop.
    https://www.windowscentral.com/how-install-windows-10-iot-raspberry-pi-3
    https://developer.microsoft.com/en-us/windows/iot/downloads
    https://www.element14.com/community/thread/64136/l/raspberry-pi-with-windows-10-iot-core?displayFullThread=true
  • Gough Lui
    0 Gough Lui over 8 years ago
    You can't run regular Windows or any other "ISOs" because the Pi is using an ARM-based CPU with a completely different instruction set to that used by normal desktop/laptop Microsoft Windows which generally runs on x86/x86-64.
    Only images built for the Pi can be used - many of them are listed at https://www.raspberrypi.org/downloads/
  • oksbwn
    0 oksbwn over 8 years ago
    You can give a shot to the following repo,
    Although it is not yet fully functional it works...
    https://github.com/andreiw/RaspberryPiPkg
  • gnatys27
    0 gnatys27 over 8 years ago in reply to jomoenginer
    Raspberry Pi with Windows 10 IoT Core
    Interested to give a try on that. thanks for pointing out.
  • nasfasder
    0 nasfasder over 7 years ago
    Certainly ,You need a detailed tutorial to guide you do it .
    Seeing this guide : https://www.passmoz.com/burn-iso-image-to-usb-in-3-ways.html
    With it , i have burned iSO file to a USB drive on computer ,I guess you can do it ,too.
  • pm3141592654@gmail.com
    0 pm3141592654@gmail.com over 7 years ago
    in short, not really windows is not compatible however there is a windows 10 like  image you can download and put on your sd card for your pi3
    you cant install windows from disks or a windows cd like on a Pc it has to be specific and targeted to be compatible with your hardware
  • cstanton
    0 cstanton over 7 years ago in reply to jomoenginer
    There's also this, which will be more like what gnatys27  requested:
