Raspberry Pi Forum Does it have a warranty?
  • Subscribers 706 subscribers
  • Views 1546 views
  • raspberry_pi_space
trishanu
trishanu over 8 years ago
Does it have a warranty or return policy?
  • hlipka
    0 hlipka over 8 years ago
    It has the same warranty as anything else you by from Farnell. Most probably this depends on the country you are in, and its laws regarding warranties.
  • gsgill112
    0 gsgill112 over 8 years ago
    If you got it from a local reseller, then NO.
  • hlipka
    0 hlipka over 8 years ago in reply to gsgill112
    Even from a reseller, local laws should apply (e.g. if its DOA it can be returned to the reseller).
  • Gough Lui
    0 Gough Lui over 8 years ago
    Your unit should have come with a warranty policy slip of paper in the box (they usually do). Take the time to look for it and read or, or ask your supplier.
    Generally, there may be certain rights that you may have depending on where you bought it and the local laws, however, with most development and prototyping gear, warranties are quite restricted due to the nature of the product. Many warranties are covering manufacturing defects only - if you have "accidentally" abused the unit (e.g. by applying the wrong voltage) or mistreated it (e.g. used it outside of an ESD protected environment) or physically damaged it, this is not covered by the warranty. Neither is damage caused by third-party add-ons which may connect to the unit (e.g. faulty power supply, HAT connector accessory). Most warranties also exclude consequential damages (e.g. if the Pi fries your SD card).
    - Gough
  • gsgill112
    0 gsgill112 over 8 years ago in reply to hlipka
    I am sorry to say, but that doesn't apply , if I buy something from a local retailer in INDIA.
    //GS Gill
