Raspberry Pi Forum pwm of raspberry pi 3 model b
  • Answers 2 answers
  • Subscribers 706 subscribers
  • Views 1444 views
monisha_123@
monisha_123@ over 7 years ago
Hello sir,
is every pin  of raspberry pi 3 model b can be configured as PWM ?
if yes how we use it possible?
  • cstanton
    0 cstanton over 7 years ago
    You'll find the following links useful:
    https://www.raspberrypi.org/forums/viewtopic.php?t=150254
    pigpio library
    Basically the answer to your question is 'no', and the longer answer is 'maybe, but only in software', and it's possible using Python.
  • monisha_123@
    0 monisha_123@ over 7 years ago in reply to cstanton
    thank you for your valuable reply.
    from the link it says two pwm channel are used for raspberry pi 3 model B.
    but i need to know extra pwm channel accessible or not
  • Fred27
    0 Fred27 over 7 years ago
    What are your requirements? If you're happy with it being slow and having some jitter then bit banging means it's possible on every pin. If you need critical timing or high speed then you're out of luck. There are of course add-ons that will give you more high quality PWM outputs.
