Raspberry Pi Forum BBQ smoker - automatic temperature control
  • Answers 3 answers
  • Subscribers 707 subscribers
  • Views 4202 views
  • rasberry_pi_3_b_plus
executor485
executor485 over 7 years ago
I did search, but I might just really suck at it... So hopefully I won't be the annoying person I used to hate that couldn't search properly.
Background:
I want to use my smoker to cook some delicious BBQ. But... The temperature varies HUGELY and it's based on the airflow coming into the unit. Ok, so I know there are other people with this issue, so off to the internet I go. A simple "barbecue automatic temperature controller" search in the search engine returns... HOLY CRAP?!?! A simple fan that spins faster or slower based on the temperature it reads inside the smoker, awesome!!! Oh, wait... You're telling me that something THAT simple costs upwards of $150 (on the cheap side) and going up to $400+. Alright... Y'all must be putting crack in these smokers cause that seems outrageous. There has to be a better way.
The question:
I have a raspberry pi zero already, and I even have some 5v and 12v fans with speed controllers! So... There isn't a huge leap to think adding a temperature sensor and maybe even wifi or bluetooth could be added to accomplish my goals. Does anyone have any ideas or experience with this? (not sure if a pi is the best use, maybe arduino? but being as I have a pi zero I figured I'd start here)
The ultimate dream would be a unit that has temperature sensors, connected to a pi zero (?), with a fan speed control, and a small screen (LED or simple) with buttons that let you set the expected temperature range, and maybe even allow you to adjust the fan speed based on temperature (since not all BBQ smokers will be the same fan speed to temperature adjustment).
Does this type of unit sound TRULY like it should cost $150 or more? Maybe I'm just overly insane on my expectations of cost image
  • mconners
    0 mconners over 7 years ago
    Hey Mark, I know of a few folks that have done this on weber smokey mountain cookers.
    Here is one example
    https://www.instructables.com/id/Smoker-PID-temperature-controller/
    He says ~$72. There are many other examples, but I just wanted to find you one to get you started.
    Mike
  • mconners
    0 mconners over 7 years ago in reply to mconners
    Looks like he built his with all off the shelf parts. You could probably build the PID controller and save even more money and put your Pi, arduino, or even an ESP 8266 to good use by building your own. There is a pid library for Arduino already, that ports directly to the ESP 8266, so then you get the benefit of WiFi.
    https://playground.arduino.cc/Code/PIDLibrary
    BTW, it'll be a fun project.
    Mike
  • executor485
    0 executor485 over 7 years ago in reply to mconners
    Mike,
    Thanks! I really appreciate it. This is exactly what I was looking for. Now the fun can begin, at a fraction of the cost image
  • mconners
    0 mconners over 7 years ago in reply to executor485
    Good. Glad I could help, I'm sure if you were to google around for more smoky mountain cooker mods you can find other ideas. That community in particular has a good mod following.
    Once you get started come back here and do a blog post or two about it, there are plenty of folks that would love to follow your progress.
    Mike
    0 genebren over 7 years ago
    Mark,
    First off, welcome to the element14 community.  There are a lot of helpful and friendly people here, working on a lot of interesting projects.  Speaking of interesting projects, I remembered a project that was entered in the Pi Chef contest a while back that might be helpful to you work on your smoker (The Cooker Connector - Blog #1: Overview (Pi Chef Challenge) ).
    Best of luck!
    Gene
  • sv_jeff
    0 sv_jeff over 6 years ago
    I had almoist the same problem, purchased Weber iGrill2 thermometer from these guys grillguru.org/best-smoker-thermometer/, and then the same problems started, temperature varied differently. I saw somewhere the unit you were talking about ("unit that has temperature sensors, connected to a pi zero (?), with a fan speed control, and a small screen (LED or simple) with buttons that let you set the expected temperature range"), actually. Will try to remember where exactly
