Raspberry Pi Forum Raspberry pi not booting
  • Answers 2 answers
  • Subscribers 707 subscribers
  • Views 917 views
  • rasberry_pi_3_b_plus
rahulprakasan
rahulprakasan over 7 years ago
Hai... today by mistake 5v and 3.3v shorted, after that system is not booting now just see red light when am connecting to power supply. Is there any solution to repair my raspberry pi
  • rew
    0 rew over 7 years ago
    No, not really,
    When you short the 5V and the 3.3V the (what should be) 3.3V suddenly becomes 5V. Not the other way around: There is a chip that makes the 3.3V from the 5V and it sees: Plenty of 3.3V, so I'll stay out of this, and it will let the voltage rise.
    That means you've put 5V on several chips that are rated for "Absolute maximum rating: 3.6V". Sometimes there is a bit of margin, sometimes not. I'm expecting you went beyond any margin there might have been.
    In this case, I would expect your LAN9514 chip to be fried. It has a strict 3.6V max policy and no reason to be able to handle anything more.
    In this case, I would expect your SD card to be fried. (Test it somewhere else?) Same story.
    The CPU has parts that run on 1.2V and the 1.2V is made from the 5V. The IOs however officially run from 1.8V to 3.6V, but on the raspberry pi board those are connected to the 3.3V. So besides the LAN chip it is possible you've blown up the CPU.
  • rahulprakasan
    0 rahulprakasan over 7 years ago in reply to rew
    Is there any solution to fix this.. or do i need to purchase new one
  • SGarciaV
    0 SGarciaV over 7 years ago in reply to rahulprakasan
    The sane choice is to purchase a new one. Salvador
  • rahulprakasan
    0 rahulprakasan over 7 years ago in reply to SGarciaV
    thank you... today i have checked 3.3v and ground shorted
    i want to purchase a new one
