Raspberry Pi Forum Audio
  • Subscribers 705 subscribers
  • Views 1053 views
Audio
whiskygone
whiskygone over 7 years ago
Audio not working
  • cstanton
    0 cstanton over 7 years ago
    whiskygone You're going to have to provide more information.
  • whiskygone
    0 whiskygone over 7 years ago in reply to cstanton
    I only get audio out hdmi and its skipping real bad. I have tryed a few things. Update and update bluetooth and the config. Im new to Raspberry. And thanks for reply back. I appraciate it.
  • cstanton
    0 cstanton over 7 years ago in reply to whiskygone
    Still going to need more information:
    - What Raspberry Pi are you using?
    - What are you trying to play on the Raspberry Pi?
    - Are you trying to play audio over bluetooth?
    - What software are you using on the Raspberry pi?
    Basically post as much info' as you can.
  • gam3t3ch
    0 gam3t3ch over 7 years ago
    Make sure your right click on the speaker icon to make sure the right output is selected as well as going to preferences and making sure bluetooth is set in there as well should be some volume controls.  As far as the audio skipping if there is no lag in the playing I would probably try another cable myself to see if it resolves the issue.  Also if your bluetooth speaker has an aux jack on it I would suggest trying it that way as well.  Let us know how you make out.
  • colporteur
    0 colporteur over 7 years ago
    I know the answer. Sorry, can't tell you!
    The details from your post are from chumming the proverbial Raspberry pi waters to attract the fish that has an answer.
    Your profile indicates you are new to the site. The people that frequent here will no doubt have an answer to your problem or better yet, give you some wonderful assistance in solving the issue yourself. The scary part is, you have to invest in them. They cannot help fix what they don't know is broken.
    Provide a description of hardware, operating system and software application you are trying to use. Your newly minted Element14 status isn't held against you. I'm confident both novice and senior members will offer suggestions. You're just going to have to work for your answer.
    Sean
  • colporteur
    0 colporteur over 7 years ago in reply to colporteur
    How did I do that? Get the correct answer that is. I told many time to keep it to myself. It appears to be correct answer some times.
    Sean
