Raspberry Pi Forum Can Rpi read mass flow meter ?
  • Replies 12 replies
  • Answers 9 answers
  • Subscribers 707 subscribers
  • Views 3938 views
netromaster
netromaster over 6 years ago
I am considering purchasing a coriolis mass flow meter that emits pulses for a project. I know it is quite common to read volumetric flow meters with the pi but I cannot say the same for the mass flow meter.
Now my question is this; if I purchase the coriolis meter, will I be able to hook it up to the pi as easy as the common flow meter and write code to determine flow rate and volume ?
  • colporteur
    0 colporteur over 6 years ago in reply to colporteur
    Your post reminds me of what I call white boarding. Techie's sitting around hashing out a solution to a problem. One of the few pleasures I miss now that I am retired.
    In our enthusiasm to select technology, what feels good to us may not be the best. A Doug dougw points out the pi is less than ideal for project requiring realtime response. That doesn't make it bad but maybe not a good as a device that has a better realtime response.
    I have tracked responses to my inquiries and any information I have would just be noise.
    Sean
  • Problemchild
    0 Problemchild over 6 years ago in reply to dougw
    Absolutely Doug,  I see +/- 24 V on the sensor which is obviously enough to send the RPI cooking. Still not sure how the signal comes out of that sensor is it analog/pulses what voltages etc.
    In practice you'll need a separate  signal conditioning and acquisition board then if you want to read this in to a Pi then do this via a standard Micro interface rather than direct to this beasty
