Raspberry Pi Forum Avnet SmartEdge IoT Gateway - Raspberry Pi - saving/loading OS
  • Replies 7 replies
  • Answers 3 answers
  • Subscribers 706 subscribers
  • Views 1815 views
  • smartedge
  • raspberry pi
  • smartedge iiot gateway
gcgrey
gcgrey over 7 years ago
Has anyone had success following the User Guide instructions for downloading a new image onto the device.
Specifically, I followed the directions here:
https://github.com/Avnet/smartedge-iiot-gateway-custom/tree/master/rpiboot
rpiboot builds fine
Then, as per the User Guide I connect a microUSB-USB cable to the microUSB on the top of the gateway PCB and to the Linux PC, and then run rpiboot.
The terminal reports:
Waiting for BCM2835/6/7
Sending bootcode.bin
Successful read 4 bytes
Second stage boot server
File read: start.elf
Second stage boot server done
All looks good - the second boot should have loaded the default msd directory (adding -d msd makes no difference) but the mass storage device never appears.
The gateway should now show the emmc /boot and /rootfs as USB storage devices but it does not.
Has anyone got this to work?
An alternative would be if the second stage bootloader could then use the USB ports as boot file systems (ie install an image onto a USB stick and boot from it) but I do believe this functionality is supported.
George
  • gcgrey
    0 gcgrey over 7 years ago
    I suspect that this has not actually been tried out/tested .... anyone from Avnet have any thoughts/comments?
  • clem57
    0 clem57 over 7 years ago in reply to gcgrey
    My guess no one has gotten to test this. Was this built by you or just an image somewhere?
  • gcgrey
    0 gcgrey over 7 years ago in reply to clem57
    Built from source as per directions on both RPi and on Ubuntu Linux - neither work
    Then built from latest RPi version and that doesnt work either.
    Suspect there are some differences in the Avnet HW that need changes to this code
  • clem57
    I am going to suggest for debugging, to consider te cross compiler on a more powerful machine. https://github.com/Avnet/smartedge-iiot-gateway/blob/master/README
    Once done, install QEMU for processing the ARM instructions to investigate further. Seems like the documentation indicates that is how the code was built initially.
  • atomar
    0 atomar over 6 years ago
    Hi George,
    Sorry to hear you are facing issues with the SmartEdhe Gateway image, recently we have updated the page with the tested final image, plz give it a try. Thanks
    Here is the direct image link:
    http://avnet.me/smartedge-iiot-gateway-releases
    Ankur Tomar
  • wsradcliffe
    0 wsradcliffe over 6 years ago
    Hi George,
    The instructions for making the rpiboot utility at the SmartEdge github site (https://github.com/Avnet/smartedge-iiot-gateway-custom/tree/master/rpiboot) have been corrected to use our special boot files.
    Please try the updated instructions, repeated below, to properly mount the Gateway as mass storage.
    git clone github.com/.../smartedge-iiot-gateway-custom.git
    cd smartedge-iiot-gateway-custom/rpiboot
    sudo apt-get install libusb-1.0-0-dev
    make
    sudo ./rpiboot -s -d avnet/
    Scott
    0 Jan Cumps over 6 years ago in reply to gcgrey
    Some more details in another related thread here: https://www.element14.com/community/message/284726/l/re-avnet-smartedge-iiot-gateway-image-install#284726
