Raspberry Pi Forum piface shime RTC installation issue
  • Replies 9 replies
  • Subscribers 703 subscribers
  • Views 2138 views
dolf1958
dolf1958 over 6 years ago
I'm new here.
Purchased an piface shime RTC
Installation was OK
But I get no response from the RTC looks that i'm on the incorrect i2c line
I2cdetect -y 1 returns a UU on address 0x06f.
But when i have a sudo hwclock -- verbose it returns with
clock from util-linux 2.33.1
System time : 1580305453.029915
Trying to open: /dev/rtc0
no usable clock interface found
On ls /dev/i2c-* it returns /dev/i2c-1
and on ls /dev/ it shows a rtc0
Can anybody support me in getting the installation correct?
  • cstanton
    0 cstanton over 6 years ago
    Have you enabled i2c in the raspi-config ?
  • dolf1958
    0 dolf1958 over 6 years ago in reply to cstanton
    Yes I2C is enabled
  • colporteur
    0 colporteur over 6 years ago
    Looking at the date your profile was created, welcome to the Element14 Community.
    I have done some dabbling with Pi RTC. https://www.element14.com/community/message/276904/l/pi-configuration-for-real-time-clock#276904  is a post trying to find some understanding.
    Below is a procedure I used to get a DS3231 RTC working last year. Not sure what chipset your RTC is using. I would assume it would need a driver loaded using a configuration similar to this. Unfortunately, the time architecture in the Pi appears to get further development and users are left to discover how to get it working once again.
    Using your favourite text editor, add a call for the kernel to support a RTC on boot to the bottom of the /boot/config.txt file – a reboot is required for this change to take effect:
    #enable RTC DS3231
    dtoverlay=i2c-rtc,ds3231
    Now that we have a time reference, let’s remove the two software packages that Raspbian uses for supporting time. From the command line interface (CLI), issue the following command to remove the NTP and fake hardware clock software:
    sudo apt-get purge ntp fake-hwclock
    Using the CLI, let’s establish the time zone configuration by entering the following command and following the prompts.
    sudo dpkg-reconfigure tzdata
    Now let’s establish the date and time. This can be done through the command line using the sudo date --set ‘yyyy-mm-dd hh:mm:ss’ command. That requires a little more typing than needed, so while the device is connected to a network, we’ll cheat and use an online time source to nail up the date and time.
    sudo apt-get install ntpdate
    sudo ntpdate <replace with the URL or IP address of a time source, this includes the parenthesis>
  • dolf1958
    0 dolf1958 over 6 years ago in reply to colporteur
    Dear Sean,
    Thanks for our input
    The chip on the pcb is different so I have used
    dparam=i2c1=on
    dtoverlay=i2c-rtc,mcp7940x
    Unfortunatly I could not get it working with your info
  • dolf1958
    Dear All
    It apears that the driver is installed correct because I get UU on postion 6f by the i2cdetect 1
    but hwclock -r responds an error
  • colporteur
    0 colporteur over 6 years ago in reply to dolf1958
    I found this post https://www.raspberrypi.org/forums/viewtopic.php?t=17597  for the chip you have specifically. You may have already tried these steps. There are a few command lines that I have found useful in the past.
    0 shabaz over 6 years ago
    Hi Dolf,
    There's a PiFace webpage here, with a PDF link at the bottom of the page, which contains a link to a script to enable the Piface RTC.
    PiFace – PiFace Real Time Clock
  • dolf1958
    0 dolf1958 over 6 years ago in reply to shabaz
    Dear Shabaz,
    I followed the link and installed for the 3e time.
    In the installation it indicate to check the Piface rtc status with
    sudo systemctl status pifacertc  the respond is
         pifacertc.service - LSB: add the piface RTC
              Loaded: loaded (etc/init.d/pifacertc; generated)
              Active: inactive (dead)
                   Docs:systemd-sysv-generator(8)
         System time : 1580501281.636260
    0 shabaz over 6 years ago in reply to dolf1958
    Why did you install the script 3 times?
    Perhaps you may need to check the connections. It's a silly product anyway (relying on slight pressure to make electrical contact).
