Raspberry Pi Forum Back again with button problem
  • Subscribers 702 subscribers
  • Views 677 views
rcayot
rcayot over 6 years ago
Well, I got my traffic light model working well with help from this forum.  Now I am trying something a little bit different.  I have several scripts that flash a set of LEDs with different patterns.what I would like to do is use a single button to switch between patterns.
i have the callback function working, but even if I record and increment button pushes, I don't seem to be able to use an additional button push to jump to the next block.
if anyone knows of an example, please point me to it.  Or, if straight forward, please post.
roger
    0 dougw over 6 years ago
    Use the button to increment a counter.
    Use If statements to execute different routines for each count value.
  • rcayot
    0 rcayot over 6 years ago
    okay, got it done.  simplified two patterns, and focused on the loops.  really had to trial and error this one, but I AM persistent.
    Roger
    import RPi.GPIO as GPIO
    from gpiozero import Button, LED, Buzzer
    from time import sleep
    from signal import pause
    red1 = LED(25)
    red2 = LED(6)
    yel1 = LED(12)
    yel2 = LED(19)
    grn1 = LED(20)
    grn2 = LED(13)
    GPIO.setup(18, GPIO.OUT, initial=GPIO.LOW)  # buzzer
    GPIO.setup(26, GPIO.IN, pull_up_down=GPIO.PUD_UP)
    GPIO.setup(21, GPIO.IN, pull_up_down=GPIO.PUD_UP)
    global ontime
    global offtime
    ontime = [.1, .2, .3, .4, .5]
    offtime = [.5, .4, .3, .2, .1]
    # Buzz = Buzzer(18)
    # btn1 = Button(26)
    # btn2 = Button(21)
    # ont = 0.2
    # offt = 0.2
    btncount = "global"
    btncount = 0
    def btn1(channel):
        global btncount
        btncount += 1
        print(btncount)
        if btncount == 3:
            btncount = 0
    GPIO.add_event_detect(26, GPIO.FALLING, callback=btn1, bouncetime=300)
    seq = [red1, red2, yel1, yel2, grn1, grn2]
    while True:
        if btncount == 0:
            for x in seq:
                x.blink(.1, .1, 3)
                sleep(.2)
                pause
        elif btncount == 1:
                red1.blink(.5, .5)
                sleep(1.1)
                if btncount == 2:
                    red1.off()
                pause
        else:
            red2.blink(.5, .5)
            sleep(1.1)
            pause
