Raspberry Pi Forum Pi Desktop - RPi4
  • Answers 2 answers
  • Subscribers 703 subscribers
  • Views 1426 views
  • rpi 4
  • pi desktop kit
Pi Desktop - RPi4
powderjockey
powderjockey over 6 years ago
Is there a Pi Desktop box available for the Raspberry Pi 4 board? Or will there be? Similar to https://canada.newark.com/element14/pi-desktop/accessory-type-desktop-computer/dp/05AC3756
  • toolkitman
    0 toolkitman over 6 years ago
    have a look here: https://www.thingiverse.com/thing:4434386
  • powderjockey
    0 powderjockey over 6 years ago in reply to toolkitman
    Thanks for the link. I was looking for a similar unit as the RPI 3 as I wanted more than just a case. I wanted the add-on board, power switch and the ability to essentially have a desktop box, etc.
  • cstanton
    0 cstanton over 6 years ago
    The add-on board included with the Pi Desktop will likely work on the Raspberry Pi 4, it's just that the enclosure won't match the Pi 4 layout. The scripts would also need to be adapted to work with the latest version of Raspbian.
  • aswinvenu
    0 aswinvenu over 6 years ago
    Hi Scott,
    There is no such RPi 4 desktop available according to my knowledge. But I cam be pretty sure that it will appear any time soon.
    But I can propose some hack solution for now.
    Get the RPi Kit.
    https://canada.newark.com/element14/pi-desktop/accessory-type-desktop-computer/dp/05AC3756?COM=RaspberryPi
    https://www.sparkfun.com/products/14354
    Right now it will not support RPi 4. Because the PCB layout has been changed from 3B+ to 4. But you can use the PCB HAT in my opinion. You may have to reconfigure the GPIO numbering and tinker with code a bit.
    But I am sure it will work.
    The casing is completely unusable. If you know 3D modeling, You can 3D print one for few dollars. Or you can ask help from someone in the community.
    Sounds like an interesting problem to solve.
    Let me know you thought,
    Aswin
