Raspberry Pi Forum Interchangeable Adapter for RPI4 B model
  • Replies 7 replies
  • Subscribers 703 subscribers
  • Views 1537 views
vinuthavaze
vinuthavaze over 6 years ago
I am looking for a Interchangeable plug type adapter with BIS (Indian) approval .
  • aswinvenu
    0 aswinvenu over 6 years ago
    Can you give some more information about what adapter you are talking about? For the GPIO connectors ?
  • colporteur
    0 colporteur over 6 years ago
    Your profile membership date suggests you are new to the E14 Community, welcome.
    Can you clarify what connector you are looking to adapt? Is it power, HDMI or some other. You indicate BIS (Indian approval). I suspect power but what is it you are trying to do. Interchange power adapter? Just not sure.
  • vinuthavaze
    0 vinuthavaze over 6 years ago in reply to colporteur
    Hi I am looking for Adapter (15W ) for Raspberry PI 4 Board with Type C Output connector for Indian Market .
  • colporteur
    0 colporteur over 6 years ago in reply to vinuthavaze
    I found a Raspberry Pi 4 B power supply for the India market at https://export.farnell.com/raspberry-pi/sc0217/rpi-power-supply-usb-c-5-1v-3a/dp/3106945
    What is ironic is the AC plug type and the DC plug type are both type C. I attached the datasheet that was available with the product.
    image2875936.pdf
  • vinuthavaze
    Hi Sir
    I am unable to find a BIS Certified adapter for Indian market
  • colporteur
    I am assuming the link I provided https://export.farnell.com/raspberry-pi/sc0217/rpi-power-supply-usb-c-5-1v-3a/dp/3106945?COM=RaspberryPi  is not working for you? This is a product for the India market.
    I find it hard to fathom there is not a product for a market as large as India.
  • aswinvenu
    Hi Vinutha,
    You are right Raspberry Pi 4 charger is not BIS certified. But you can use any BIS certified USB adapter with  3Amps output.
    I just saw this in amazon. https://www.amazon.in/Powerup-Charged-Certified-Adapter-Smartphones/dp/B07D9NKQCQ
    The other option is getting Raspberry pi charger BIS certified. I am not sure how much will that cost. Since it has FCC Part 15 SDOC    ICES-003    CB Test Certificate    GS Certificate    LVD 2014/35/EU certificate     UL Energy Efficiency Certificate     NOA UL Leaf Mark    SAA    RCM . Getting BIS won't be a deal. But again it may cost you a bit. If your application has that budget bandwidth go for it.
    Aswin
