Raspberry Pi Forum Raspbery Pi Zero GPIO keyboard driver
  • Subscribers 703 subscribers
  • Views 2014 views
  • raspberry pi zero
  • keyboard matrix
  • ben heck
  • matrix gpio
  • keyboard driver
  • zero
  • 244-tbhs
the_antithesis
the_antithesis over 5 years ago
So I am building a project that uses a Raspberry Pi Zero. I have the files Ben Heck used to use the GPIO for the keyboard matrix, however, I am need a different key layout. More importantly, a layered key layout sine it's a 40% design, similar to a Planck keyboard. Unfortunately, I don't know how to code and cannot information on how to do what I need to do. Where should I go to find information on implementing a layered keyboard matrix through the GPIO using this software?
  • amgalbu
    0 amgalbu over 5 years ago
    Hello Jack
    in general if you have a keyboard matrix with "r" rows and "c" columns, you have to configure "r" GPIOs as outputs and "c" GPIOs as inputs
    Then, in your code you have to create a loop where
    1. set the i-th output to 1 and all the other outputs to 0 (i ranges from 1 to "r")
    2. read all the "c" inputs. If an j-th input is read as 1, the key at position (i, j) has been pressed
    Bye and good luck for your project!
    Ambrogio
  • the_antithesis
    0 the_antithesis over 5 years ago in reply to amgalbu
    Okay, but how to I make a layered layout. I'm working with only 48 keys and need to use keyboard layers. I found this software here, which should do what I need but I'm unsure of the syntax to add a second keyboard layer using the FN_1 key to switch layers and to set it as a toggle. This is the code I need to alter:
    https://github.com/thebenheckshow/244-tbhs-raspberry-pi-zero-portable/tree/master/Code/Keypad
    The layout is in 244-tbhs-raspberry-pi-zero-portable/Code/Keypad/Build/source/Keypad_Driver_V13.c
  • amgalbu
    0 amgalbu over 5 years ago in reply to the_antithesis
    Sorry Jack
    You have to handle keyboard layers in software
    So, basically
    1. add an integer variable (let's call this variable fn_status) to Keypad_Driver_V13.c
    2. copy&paste array "abc", rename it abc_1 and fill it with the proper values
    3. when FN_1 is pressed, toggle the value of fn_status (fn_status != fn_status)
    4. in the main() function, replace
       if ( returnKeyPress != -1 ){
       send_event(fd, EV_KEY, abc[returnKeyPress], 1);
    with something like
       send_event(fd, EV_KEY, (fn_status)? abc_1[returnKeyPress] : abc[returnKeyPress], 1);
    Obviously this is just to give you an idea. Many other approaches are possible
    Bye!
    Ambrogio
