Raspberry Pi Forum Pi4 wont boot
  • Replies 14 replies
  • Answers 12 answers
  • Subscribers 708 subscribers
  • Views 5373 views
  • not booting
  • pi4
Pi4 wont boot
cptang
cptang over 5 years ago
got my pi4 but it just can't boot
2 long green flash follow by 8 short flash, and even fail to show the rainbow screen.
Try different SD card or enable the hdmi_force_hotplug=1, both not work
The card is OK to boot a pi3 so probably not the SD card problem.
Try update bootloader still the same
Any ideas ?
    0 dougw over 5 years ago
    What video port were you using? - the video didn't show a video cable. (the port nearest the power connector is the boot video port)
    This isn't the reason for the odd flashing pattern, just included in case it helps someone.
    More tips on Pi4 boot issues:
    https://www.youtube.com/watch?v=JYrGoLbiyj8&ab_channel=EVMYT
  • colporteur
    0 colporteur over 5 years ago in reply to kmikemoo
    I suffer from familiarites. I assume when a person gets involved with SBC or microcontrollers, they become so immersed that they become infected with the same condition. It causes the wearer to narrow focus. Some things become less important yet may in the end cause problems.
    As DW dougw points out in his post, I assume when you suggest video connected, that means a correct cable, that is know to work, is connected from the correct video port to the correct video input and that input is selected to display content. Any number of things in that scenario can be wrong and as a result no video. When I say video doesn't work, it is a know tested path used to confirm a problem.
    I have been told and continue to fail in reducing the knowledge of the individual. If I get the impression you have knowledge, I don't challenge it. Unfortunately, that bites me in the *** more often than I like. Yeah, they spin a good story but have no idea what they are talking about.
    I have a proliferation of Pi's that makes a simple won't boot, relatively easy to isolate. I also have a wealth of experience that I can draw on to help get over humps. I accept there are scenarios that exist where shite doesn't work.
    A know working SD card in a known working Pi, moved to a Pi that doesn't work to me points to the hardware. Now I confess I have SD card that generate chronic problems. They work on some stuff but not on other. Technology for fun is a ***.
  • Sean_Miller
    0 Sean_Miller over 5 years ago in reply to dougw
    That's where I'm at - there needs to be a micro-HDMI cable connected between the Pi and the monitor.
  • colporteur
    Just received this link.
    https://magpi.raspberrypi.org/articles/become-a-raspberry-pi-genius?mc_cid=921bf53532&mc_eid=d5007f545a
    describes boot and LED indications.
