Raspberry Pi Forum Pi4 wont boot
  • Replies 14 replies
  • Answers 12 answers
  • Subscribers 706 subscribers
  • Views 5464 views
  • not booting
  • pi4
Pi4 wont boot
cptang
cptang over 5 years ago
got my pi4 but it just can't boot
2 long green flash follow by 8 short flash, and even fail to show the rainbow screen.
Try different SD card or enable the hdmi_force_hotplug=1, both not work
The card is OK to boot a pi3 so probably not the SD card problem.
Try update bootloader still the same
Any ideas ?
  • colporteur
    0 colporteur over 5 years ago
    I see by your profile you are newly minted in the E14 Community, welcome and I do hope someone can help.
    The test of moving the SD card to another host and it booting is a solid move to troubleshoot the SD Card. The next issue would be power? What are you using for a power supply. Power has caused me problems in the past.
    Are you able to display video through the boot process? There is a pattern to the boot process that the display might offer some insight.
  • gdstew
    0 gdstew over 5 years ago in reply to colporteur
    This is very true. The Pi 4 specifies a 15W (5.1V @ 3A) power supply. The official Pi 4 power supply meets this spec as do several other suppliers
    and a few offer slightly higher output voltage, usually 5.2V. If you go the with something other that the official supply make sure it is using 18 AWG
    wire in the power cable so it can supply the 3A without significant voltage drop.
    0 DAB over 5 years ago
    Go get the latest (July) RPi Magazine.
    They describe what the flashes mean.
  • gdstew
    0 gdstew over 5 years ago in reply to DAB
    I checked it out and the two long eight short sequence is not on the list. There is only one eight short flash sequence listed and it is after zero long flashes
    for a SDRAM failure. The next closest is 4 long and seven short for a Power failure type B. There is no explanation of what that actually means and there is
    a  Power failure type A that also lacks an explanation of what it is or what the difference between them is. I went to the link at the bottom of the last paragraph
    (magpi.cc/blinkwarnings) and it doesn't offer any explanation either.
  • cptang
    0 cptang over 5 years ago in reply to gdstew
    Hello Sean and Gary,
    Thx
    I do use a Pi4 power supply from seeed studio. I also try another pi 4 power supply though but same result.
    I find nothing output to the monitor.
    Also try “Raspberry Pi 4 EEPROM boot recovery”, it seems work since i saw the green LED blinking continuously then off.
    Nevertheless the LED flash code is attached below.
  • gdstew
    0 gdstew over 5 years ago in reply to cptang
    Sure looks like 2 long and 8 short to me! It would be much more helpful if the documentation was complete with regard to these error codes.
    And I did try to find it. Here is what is what I found on the official Raspberry Pi web site:
    Long flashesShort flashesStatus
    03Generic failure to boot
    04start*.elf not found
    07Kernel image not found
    08SDRAM failure
    09Insufficient SDRAM
    010In HALT state
    21Partition not FAT
    22Failed to read from partition
    23Extended partition not FAT
    24File signature/hash mismatch - Pi 4
    44Unsupported board type
    45Fatal firmware error
    46Power failure type A
    47Power failure type B
  • colporteur
    0 colporteur over 5 years ago in reply to cptang
    No video output is disconcerting and would give me causes to abandon further troubleshooting. An inexperienced users with a new Pi may have difficulties. Once you eliminate the normal stuff, power and SD card there is not much else in the users domain to troubleshoot.
    Have you open a trouble call with the vendor? I suspect you are at that point. Especially considering it is new.
  • kmikemoo
    0 kmikemoo over 5 years ago
    cptang  I'm going to go out on a limb and recommend reflashing the SD card with the latest Raspberry Pi OS.  It's a long shot but not all generations of RPiOS are created equal.  It's one more thing you can say you tried before getting the return authorization from your supplier.
  • colporteur
    0 colporteur over 5 years ago in reply to kmikemoo
    A reflash is a simple step to repeat. If it was me by this time I would have reflashed a number of times on a number of different cards.
    The Achilles heal isthe current flashed SD card works in another Pi and there is no video on boot.
  • kmikemoo
    0 kmikemoo over 5 years ago in reply to colporteur
    colporteur  I did think on the fact that the SD card worked in another Pi, but it may not have been another Pi4.
    I think back on a Pi3 that would not boot so I threw it in the trash and bought a replacement.  Not satisfied, I dug the old one out of the trash and kept researching.  There was something in the newer versions of the RPiOS that the Pi3 wanted to see and it wasn't on the OS on my SD card - so I updated it with the (new to me) Raspberry Pi Imager and WHOA!!!!, my rescued RPi3 worked just fine.
    If the other Pi was a Pi2 - because we all have at least one of those still about, one might get misled that the OS is sufficient for the Pi4. <- Maybe.  I haven't tried to validate this, ergo... going out on a limb.  <thumbs up>.
    Edit:  Reread the original post.  CP did say the other Pi was a RPi3.  Still worth trying - IMHO.
