Raspberry Pi Forum Software for PiFace
  • Replies 14 replies
  • Answers 2 answers
  • Subscribers 709 subscribers
  • Views 2694 views
  • raspberrypi
Software for PiFace
I have just bought a PiFace board but after two days of trying I cannot obtain any software to run it. I have tried https:// github.com and it returns "no such file or directory. I've tried PiFace Digital, "Getting Started with PiFace Digital in less than ten minutes", on the page starting "you can always enable the SPi driver .................. The software appears to have downloaded and installed but the PiFace Emulator doesn't work. (I used the command piface/scripts/piface_emulator) and it returned "no such file or directory".
Can someone spot where I'm going wrong please?
  • penguintutor
    0 penguintutor over 12 years ago
    This discussion is over a month old now, but there is now a new official PiFace website with some good documentation on it.
    http://www.piface.org.uk/
    There is some actualization about how to fix this problem?
    I am having exactly the same issue. I bouth a piface and and i have tried to install the software several time and I always achieve:
    SPIInitError: I can't see /dev/spidev0.0. Have you enabled the SPI module? (htt\ p://piface.github.io/pifacecommon/installation.html#enable-the-spi-module)
    I have followed all the instructions named in this conversations but it doestn work.
    Can you all guys please help me?
    Cheers!
  • rigpa
    0 rigpa over 9 years ago
    I'm having the same issue. I've tried enabling the SPI module with raspi-config. After enabling, it still returns the same result as shown above.
    Also trying the emulator gives the following result.
    $ pifacedigital-emulator
    Error initialising PiFace Digital:  I can't see /dev/spidev0.0. Have you enabled the SPI module? (http://piface.github.io/pifacecommon/installation.html#enable-the-spi-module)
    Running without hardware PiFace Digital.
    pifacedigital-emulator: cannot connect to X server
    Could anyone come to our aid?
  • rigpa
    This somehow solved it for me : (found this on GitHub) https://github.com/piface/pifacecommon/issues/7
    ... Don't know what caused the SPI module to be missing in the first place, and don't know what exactly fixed it, but oh well, it works now.
    grillo7 commented on Mar 31, 2014
    Tom
    I have solved it by installing spidev0 and spidev0.1 files with this proccedure:
    http://neophob.com/2012/08/raspberry-pi-enable-the-spi-device/
    I don't know why, but the original distribution of raspbian doesnt include it, you can even set SPI true in the raspi-config screen, but it doesnt work if the spidev0 and pidev0.1 files are not installed. Maybe it coul be nice if the instalation of pifacedigital-emulator could verify if and if it is missing, then auto installing.
    Another little issue I found in the spidev0 instalation proccedure, is that you have to install/upgrade firmware files, then other devices depending on the version istalled(like wifi dongle in my case) can be misconfiguerd.
