Raspberry Pi Forum Software for PiFace
  • Replies 14 replies
  • Answers 2 answers
  • Subscribers 709 subscribers
  • Views 2692 views
  • raspberrypi
Software for PiFace
I have just bought a PiFace board but after two days of trying I cannot obtain any software to run it. I have tried https:// github.com and it returns "no such file or directory. I've tried PiFace Digital, "Getting Started with PiFace Digital in less than ten minutes", on the page starting "you can always enable the SPi driver .................. The software appears to have downloaded and installed but the PiFace Emulator doesn't work. (I used the command piface/scripts/piface_emulator) and it returned "no such file or directory".
Can someone spot where I'm going wrong please?
    Documentation is here: http://piface.github.io/pifacedigitalio/
    Dear Tom,
    I have updated Raspbian and installed pifacedigitalio following your
    advice. Unfortunately blink.py failed with the report "no such file or
    directory".
    It seems that all along I've been having that report so I still need help
    I'm afraid.
    My home/pi directory at present contains the folders:
    indiecity,
    Squeak
    RPi.GPIO
    RPi.GPIO .0.5.3a
    piface
    Desktop
    Documents
    scratch
    Python Games
    python3_pifacecommon_4,0,0-1_all(1).deb
    data.tar.gz
    install_scratch_GPIO.sh
    install.txt
    debian-binary
    contro.tar.gz
    pure13.0.2.55 8en_gb.exe
    Can you try the following commands and show me the output, please?
        $ aptitude show python3-pifacedigitalio
        $ ls -l /usr/share/doc/ | grep piface
    You should be able to obtain the examples and documentation from the Github source https://github.com/piface/pifacedigitalio
    Dear Tom,
    Here is the listing for you:
    pi@raspberrypi ~ $ aptitude show python3-pifacedigitalio
    Package: python3-pifacedigitalio
    State: installed
    Automatically installed: no
    Version: 2.1.0-1
    Priority: optional
    Section: python
    Maintainer: Thomas Preston <thomas.preston@openlx.org.uk>
    Architecture: all
    Uncompressed Size: 528 k
    Depends: python3 (>= 3.2.3-3~), python3-pifacecommon (>= 3.0.0),
             python3-pifacecommon (< 4.0.0)
    Description: The PiFace Digital I/O module.
    Python 3 module for interacting with PiFace Digital. Documentation:
    pi@raspberrypi ~ $ is -l /usr/share/doc/ | grep piface
    bash: is: command not found
    pi@raspberrypi ~ $ ls -l/usr/share/doc/ | grep piface
    ls: invalid option -- '/'
    Try `ls --help' for more information.
    pi@raspberrypi ~ $
    I was confused by the typeface using your second line. Sorry.
    Chris.
    Dear Tom,
    I've done all the updating and upgrading of Raspian as per examples on
    https://github.com/piface/pifacedigitalio. The outcome of the Blink test
    was :
    pi@raspberrypi ~ $  python3
    /usr/share/doc/python3-pifacedigitalio/examples/blink.py
    Traceback (most recent call last):
      File "/usr/lib/python3/dist-packages/pifacecommon/spi.py", line 40, in
    open_fd
        self.fd = posix.open(spi_device, posix.O_RDWR)
    OSError: No such file or directory: '/dev/spidev0.0'
    During handling of the above exception, another exception occurred:
      File "/usr/share/doc/python3-pifacedigitalio/examples/blink.py", line 9,
    in
        pifacedigital = pifacedigitalio.PiFaceDigital()
      File "/usr/lib/python3/dist-packages/pifacedigitalio/core.py", line 45,
    in __init__
        super(PiFaceDigital, self).__init__(hardware_addr, bus, chip_select)
      File "/usr/lib/python3/dist-packages/pifacecommon/mcp23s17.py", line 91,
    in __init__
        super(MCP23S17, self).__init__(bus, chip_select)
      File "/usr/lib/python3/dist-packages/pifacecommon/spi.py", line 32, in
    __init__
        self.open_fd(spi_device)
      File "/usr/lib/python3/dist-packages/pifacecommon/spi.py", line 44, in
    open_fd
        % (spi_device, SPI_HELP_LINK)
    pifacecommon.spi.SPIInitError: I can't see /dev/spidev0.0. Have you enabled
    the SPI module? (
    http://piface.github.io/pifacecommon/installation.html#enable-the-spi-module
    pi@raspberrypi ~ $
    I hope this is useful to you. I saw no activity on the PiFace board. Is it
    my error perhaps? Can you offer any other ideas please?
    Chris Hart
    Thanks for suggestion. I have followed this through to the letter and ended up with a puzzling result with the blink.py routine failing once again with a directory problem:
    pi@raspberrypi ~ $  python3 /usr/share/doc/python3-pifacedigitalio/examples/blink.py
    File "/usr/lib/python3/dist-packages/pifacecommon/spi.py", line 40, in open_fd
    OSError: [Errno 2] No such file or directory: '/dev/spidev0.0'
    Chris.
  • mconners
    0 mconners over 12 years ago in reply to e14 Contributor
    One thing immediately jumps out at me
    the SPI module?
    Have you? I would suggest following the link and see where that takes you.
    The error seems to be that the driver for the SPI is not loaded, therefore the OS doesn't know about /dev/spidev0.0
    On Unix (and by extension Linux) systems most of the IO is handled as if the device were a file, so when a device driver is loaded the OS will create a "file" in the /dev/ directory corresponding to the device. In this case the SPI device.
    If that file is not found, it probably means that the driver for the file isn't loaded, or you don't have permission to access it.
    I haven't had the opportunity to play with the PiFace yet, but I would suspect that your error has something to do with the module not being enabled.
    I briefly visited this page
    Installation — PiFace Common 4.0.0 documentation
    which is the same as the link above and it seems to have the information you need.
    Good Luck,
    Mike
    Dear Tom,
    I have got the PiFace to respond by having gone into Config Advanced and
    setting SPI to "Yes" following advice at:
    I'm looking forward to learning how to set up and run some interesting
    projects.
    Kind regards,
    Chris. Hart.
  • jspage
    0 jspage over 12 years ago
    pifacedigital-emulator works straight off the prompt for me
