Raspberry Pi Forum How can I have PCI or PCI-Express on Raspberry PI?
  • Replies 11 replies
  • Subscribers 707 subscribers
  • Views 12149 views
  • pci
  • slot
  • pcie
Hello all,
I have a simple question.
I want to use raspberry pi to create a telephone exchange.
I need to use an ISDN BRI but i only can find PCI or PCI-Express boards.
How can I put a PCI/PCI-E on Raspberry Pi Board?
Or how can I fix that situation using Raspberry pi?
Ricardo Silva
  • johnbeetem
    0 johnbeetem over 12 years ago
    In principle, you could go over USB using a USB to PCI "reverse bridge".  BRI is slow, so it should be fine over a USB connection.  There are chips that do the USB to PCI function such as the PLX NET 2282 but I don't know if there are boards available that use this or other chips so that you can just plug a couple boards together.
    Even if you can find the hardware, getting things to work at the device driver level could be difficult.  Good luck!  image
  • bad_boy_y
    0 bad_boy_y over 12 years ago
    Maybe with than http://www.xmos.com/startkit they already have lots of pcie for the raspberry pi.
  • johnbeetem
    0 johnbeetem over 12 years ago in reply to bad_boy_y
    If I understand their documentation correctly, XMOS startKIT has a PCIe connector, but the signals aren't PCIe.  They're just using PCIe as a convenient, inexpensive connector.
  • bad_boy_y
    oops the PCIe connector is a GPIO and can be use with their board
  • bad_boy_y
    Lot of PCIe board look like to have direct usb port or adapter is available.
    http://www.mfactors.com/mp1-mini-pci-e-pci-e-adapter-ver-1-0a/
    0 e14 Contributor over 12 years ago in reply to johnbeetem
    Yes - that is correct John; the startKIT PCIe slot enables people to plug in a PCB without having to buy funky connectors.
    Instead of going with a ISDN PCI card, why don't you go with a ISDN to SIP gateway like a  MediaPack 408, ISDN VoIP gateway.  I am not endorsing this device but I have had pretty good luck with a MediaPack MP118, PSTN to SIP gateway.   I have also been looking into moving from an old desktop, converted to Asterisk, to a PI.  As you can see, I don't have to worry about any PCI or PCIe.  :-)
  • lucio57
    0 lucio57 over 10 years ago
    The PCIE2RASPI board could solve your issues, it can join a PCIE board (mini or standard) with a CycloneIV GX Fpga to the IO signals of the Raspberry I/O board. Cutting the power pins on the header it can be fitted by a flat cable to a Raspberry host. The Fpga on mini PCIe host an end point that have master target capability, de fact it make the Raspberry able to read or write the PC memory.
    Look at:
    http://www.geb-enterprise.com/PRODUCTS/Mini_PCIe_to_Raspberry.html
    http://www.geb-enterprise.com/PRODUCTS/PCIe_Standard_PC_CARD.html
    imagePCIE-Raspberry-DS.pdf
  • clem57
    0 clem57 over 10 years ago
    I think a better solution is Gizmo II at http://www.gizmosphere.org/wp-content/uploads/2014/11/4531_Gizmo2_ProBRIEF_FNL.Element14.pdf
    because you get x86 instructions and PCIe allowing the drivers to be used with ISDN.
    Clem
  • vanthome
    0 vanthome over 7 years ago
    There is a new product sbcpoe-rpi3b+-mpcie from n-fuse that actually offers a mini PCIe slot for the Raspberry PI with a small modification (wire soldered to USB test pins). Naturally it can't offer a PCI lane as the RPi does not expose a PCI bus in any way. In addition, it offers Power Over Ethernet functionality for the RPi 3B+.
    https://www.n-fuse.co/devices/SBCPoE-RPi-Power-over-Ethernet-Hat-for-Raspberry-Pi-3B-plus-with-mPCIe-Slot.html
