Raspberry Pi Forum No Module found error
  • Subscribers 683 subscribers
  • Views 641 views
  • pifacecad
  • piface_control_and_display
  • raspeberry_pi_accessories
  • piface_control_&_display
  • piface_control&display
  • piface_control
  • piface
I've followed the instructions at Installation — PiFace Control and Display (CAD) 2.0.6 documentation to install the libraries an example code. When I try to run the sys info example, using python3 /usr/share/doc/python3-pifacecad/examples/sysinfo.py , I get
pi@raspberrypi  $ python3 /usr/share/doc/python3-pifacecad/examples/sysinfo.py
Traceback (most recent call last):
  File "/usr/share/doc/python3-pifacecad/examples/sysinfo.py", line 5, in <module>
    import pifacecad
  File "/usr/lib/python3/dist-packages/pifacecad/__init__.py", line 19, in <module>
    from pifacecommon.interrupts import (
ImportError: No module named interrupts
I can get the python2 example to work, but none of the python3 examples work, giving the same error.
I'm using an old Raspbian install that has been fully updated.
Looking at pifacecommon.py, it doesn't appear to have been updated since apr 25, yet it does on Github
pi@raspberrypi /usr/local/lib/python3.2/dist-packages $ ls -al
total 52
drwxrwsr-x 5 root staff  4096 Nov 17 17:26 .
drwxrwsr-x 3 root staff  4096 Sep 18  2012 ..
drwxr-sr-x 2 root staff  4096 Nov 17 17:26 .AppleDouble
-rw-r--r-- 1 root staff  2439 Apr 25  2013 asm_generic_ioctl.py
drwxr-sr-x 5 root staff  4096 Nov 17 17:26 pifacecad
-rw-r--r-- 1 root staff   267 Apr 25  2013 pifacecommon-1.0.egg-info
-rw-r--r-- 1 root staff  5797 Apr 25  2013 pifacecommon.py
-rw-r--r-- 1 root staff   297 Apr 25  2013 pifacedigitalio-1.2.egg-info
-rw-r--r-- 1 root staff 10171 Apr 25  2013 pifacedigitalio.py
drwxr-sr-x 2 root staff  4096 Apr 25  2013 __pycache__
Bit lost now...
    Have you tried updating pifacecommon to the latest version with:
    $ sudo apt-get update && sudo apt-get install python3-pifacecommon
    0 Former Member over 12 years ago in reply to Former Member
    I did update, but using a different command string. But using the above, i got
    0 upgraded, 0 newly installed, 0 to remove and 9 not upgraded.
    And it still doesn't work.....
    Solved.
    I unistalled everything Piface, using apt-get -purge remove pifacexxxxx - having got a list of packages using dpkg -l Piface*
    then I removed the /usr/local/lib/python3.2/dist-packages directory, as it hadn't been removed using apt-get.
    I then rebooted.
    Re-installed pifacecad using the git wiki instructions
    It now works....though the radio is a bit flaky.....
