Raspberry Pi Forum piface-emulator not found
  • Subscribers 704 subscribers
  • Views 749 views
  • piface_emulator
having followed all the steps in the guidance for installing the piface, everything seems to go fine, the install worked without error.  However, on reboot, the instruction to start the emulator with 'piface/scripts/piface-emulator' fails. no such file or directory.
if i use the terminal to search for the file it returns no such file found too.
Any help?
    Hi John,
    Did you follow these instructions to download install it??
    https://github.com/piface/pifacedigital-emulator
    Hi chris.  No, these instructions are slightly different from the set I followed, so that gives me hope!  Will try today,
    Thanks for your help
    I downloaded and installed the PiFace Emulator with no problem, but it appears to be the wrong one! The one in the instructions says it can address more than one PiFace (using the option "View" to select which PiFace you are talking to), but the version I have doesn't have this option. I mentioned this problem a week ago, but no-one has yet told me what the  solution is.
