Raspberry Pi Forum interrupts gives memory leak
  • Replies 7 replies
  • Subscribers 701 subscribers
  • Views 1276 views
  • memory
  • interrupts
  • leak
Hi People,
I have a problem. This week I have installed my Raspberry and the PiFace. All software is the newest (install-date: 20-01-2014)
After installing, I tested it with: python3 /usr/share/doc/python3-pifacedigitalio/examples/blink.py
works fine.
When I test this script with Unix command: "top" to see the memory use, the %mem is stable.
When I start (from: /usr/share/doc/python3-pifacedigitalio/examples ):
python ./presslights.py &
or by
python3 ./presslights.py &
the memory use is rising.
After 5 to 8 hours the scripts runs "out of memory".
The only difference with the blink.py script is:
   pifacedigital = pifacedigitalio.PiFaceDigital()
   listener = pifacedigitalio.InputEventListener(chip=pifacedigital)
   for i in range(4):
       listener.register(i, pifacedigitalio.IODIR_ON, switch_pressed)
       listener.register(i, pifacedigitalio.IODIR_OFF, switch_unpressed)
   listener.activate()
An other Python-script with interrupts (and I stript it totally) gave the problem with the out of memory problem.
After this, I tested the input handling, by using polling instead of interrupts.
With polling the memory is also stable.
My questions:
- Do more people have this problem with interrupts (latest Python version)?
- How can I solve it?
Best regards from the Netherlands,
Jack.
  • Eyedoll
    0 Eyedoll over 12 years ago
    I have not experienced this. I use the "Other" PiFace, the one with the RGB LCD Display (16x2) that has 5 buttons on it.  I have not experienced any memory leaks using any of the scripts or any of modified scripts.
    0 e14 Contributor over 12 years ago in reply to Eyedoll
    Thanks for your input!
    I have tested today, and here are the results. First my script:
    #!/usr/bin/python
    import pifacedigitalio
    import time
    import MySQLdb
    from memory_profiler import profile
    @profile
    def pulsetodb(pifacedata):
      # Open database connection
      db = MySQLdb.connect('localhost', 'web', '*********', 'domotica', charset='utf8', use_unicode=True)
      # Prepare SQL query to INSERT a record into the database
      sql = "INSERT INTO raw_piface(timestamp, field, status) VALUES( %s , %s , %s )"
      try:
           # Prepare a cursor object using cursor() method
           c = db.cursor()
           # Execute the SQL command
           c.execute(sql, ( pifacedata.timestamp, pifacedata.pin_num, pifacedata.direction ))
           # Commit your changes in the database
           db.commit()
           c.close()
      except:
           # Rollback in case there is any error
           db.rollback()
           # Close database connection
           db.close()
    @profile
    def main():
      # set up listeners for buttons
      listener.register(0, pifacedigitalio.IODIR_FALLING_EDGE, pulsetodb)
      # Start listening for events.
      listener.activate()
    __name__ == '__main__' and main()
    And now the output from the memory_profiler:
    pi@domotica ~ $ python -m memory_profiler ./pif_inputs.py
    Filename: ./pif_inputs.py
    Line #    Mem usage    Increment   Line Contents
        49      7.9 MiB      0.0 MiB   @profile
        50                             def main():
        51      7.9 MiB      0.1 MiB   pifacedigital = pifacedigitalio.PiFaceDigital()
        52      8.3 MiB      0.4 MiB   listener = pifacedigitalio.InputEventListener(chip=pifacedigital)
        53
        54                             # set up listeners for buttons
        55      8.3 MiB      0.0 MiB   listener.register(0, pifacedigitalio.IODIR_FALLING_EDGE, pulsetodb)
        56
        57                             # Start listening for events.
        58      8.3 MiB      0.0 MiB   listener.activate()
        21      8.5 MiB      0.0 MiB   @profile
        22                             def pulsetodb(pifacedata):
        23
        24                             # Open database connection
        25      9.4 MiB      0.9 MiB   db = MySQLdb.connect('localhost', 'web', '~?0aU$+I63', 'domotica', charset='utf8', use_unicode=True)
        26
        27                             # Prepare SQL query to INSERT a record into the database
        28      9.4 MiB      0.0 MiB   sql = "INSERT INTO raw_piface(timestamp, field, status) VALUES( %s , %s , %s )"
        29
        30      9.4 MiB      0.0 MiB   try:
        31                             # Prepare a cursor object using cursor() method
        32      9.4 MiB      0.0 MiB   c = db.cursor()
        33
        34                             # Execute the SQL command
        35      9.4 MiB      0.0 MiB   c.execute(sql, ( pifacedata.timestamp, pifacedata.pin_num, pifacedata.direction ))
        36
        37                             # Commit your changes in the database
        38      9.4 MiB      0.0 MiB   db.commit()
        39      9.4 MiB      0.0 MiB   c.close()
        40
        41                             except:
        42                             # Rollback in case there is any error
        43                             db.rollback()
        44
        45                             # Close database connection
        46      9.4 MiB      0.0 MiB   db.close()
        21      9.6 MiB      0.0 MiB   @profile
        23
        25      9.6 MiB      0.0 MiB   db = MySQLdb.connect('localhost', 'web', '~?0aU$+I63', 'domotica', charset='utf8', use_unicode=True)
        26
        28      9.6 MiB      0.0 MiB   sql = "INSERT INTO raw_piface(timestamp, field, status) VALUES( %s , %s , %s )"
        29
        30      9.6 MiB      0.0 MiB   try:
        32      9.6 MiB      0.0 MiB   c = db.cursor()
        33
        35      9.6 MiB      0.0 MiB   c.execute(sql, ( pifacedata.timestamp, pifacedata.pin_num, pifacedata.direction ))
        36
        38      9.6 MiB      0.0 MiB   db.commit()
        39      9.6 MiB      0.0 MiB   c.close()
        40
        41                             except:
        43                             db.rollback()
        44
        46      9.6 MiB      0.0 MiB   db.close()
        21      9.7 MiB      0.0 MiB   @profile
        23
        25      9.7 MiB      0.0 MiB   db = MySQLdb.connect('localhost', 'web', '~?0aU$+I63', 'domotica', charset='utf8', use_unicode=True)
        26
        28      9.7 MiB      0.0 MiB   sql = "INSERT INTO raw_piface(timestamp, field, status) VALUES( %s , %s , %s )"
        29
        30      9.7 MiB      0.0 MiB   try:
        32      9.7 MiB      0.0 MiB   c = db.cursor()
        33
        35      9.7 MiB      0.0 MiB   c.execute(sql, ( pifacedata.timestamp, pifacedata.pin_num, pifacedata.direction ))
        36
        38      9.7 MiB      0.0 MiB   db.commit()
        39      9.7 MiB      0.0 MiB   c.close()
        40
        41                             except:
        43                             db.rollback()
        44
        46      9.7 MiB      0.0 MiB   db.close()
    As you can see, the interrupt function is showed once, but the function with SQL is called frequently. Here you can see the memory usage is rising. If the script is running for view hours, it stops on "out of memory". The problem must be in the Interrupt part.
    Who can help me?
    cheers, Jack.
    Hi Jack,
    I have the same problem of memory leaks, did you found solution ?
    Greatings Marc
  • Eyedoll
    0 Eyedoll over 12 years ago in reply to Eyedoll
    Actually, I stand corrected.  I noticed that my Pi becomes unresponsive after about 48 hours of continuous use of the time display script.
    Hi I am experiencing the same issue, the issue seems to lie with the listener as I am pretty sure that I have tried everything else including manual garbage collection and clearing all variables manually after calling the functions. Does anyone have any further insight into this as of yet or possibly a workaround?
    0 e14 Contributor over 11 years ago in reply to Eyedoll
    Hi, I have the same problem with the memory.
    It is coming from the interupt section.
    I on my way found an work around on restarting my process by a cron job every 15 minutes.
    This is working, but not the best way.
    Waiting for an solution.
    Greetings Marc
    with installed gc i got this on gc.collect()  / and memory is rising --
    [<pifacedigitalio.core.PiFaceDigital object at 0x1cfa510>,
    <pifacedigitalio.core.PiFaceDigital object at 0x1d6e5f0>,
    <pifacedigitalio.core.PiFaceDigital object at 0x1d860f0>,
    <pifacedigitalio.core.PiFaceDigital object at 0x1d95bd0>,
    <pifacedigitalio.core.PiFaceDigital object at 0x1dae6d0>,
    <pifacedigitalio.core.PiFaceDigital object at 0x1d55b10>,
    <pifacedigitalio.core.PiFaceDigital object at 0x1d46030>,
    <pifacedigitalio.core.PiFaceDigital object at 0x1dc61d0>]
