Raspberry Pi Forum Raspberry Pi Blinking on Acer Monitor
  • Subscribers 675 subscribers
  • Views 407 views
  • noobs
  • hdmi
  • raspberry-pi
  • raspberrypi
I'm using an Acer monitor with an HDMI port. I'm using NOOBS. When my Pi first boots or I go into the GUI, my monitor starts blinking. I have the HDMI boost set to 4 as suggested (it's actually defaulted). Is anyone else seeing similar issues on a multi-input monitor? I'd rather not have to use my TV.
- Kurschun
  • johnbeetem
    0 johnbeetem over 11 years ago
    I had an HDMI display problems when I was using RasPi with an iffy power supply.  First I would see random dots, and then the display would blank out.  I recommend measuring RasPi's 5V level between TP1 and TP2 (ground).  It should be between 4.75V and 5.25V for reliable operation.  In my case I could go down to 4.65V with no problems, but below that HDMI would start to misbehave.  See the RasPi Troubleshooting Wiki: http://elinux.org/R-Pi_Troubleshooting#Interference_visible_on_a_HDMI_or_DVI_monitor
    Most RasPi problems have to do with getting 5V to the board.  Even if you have a good 5V power supply, many Micro USB cables have very thin conductors which give you enough of a voltage drop that TP1 drops below 4.75V.  The RasPi Troubleshooting Wiki has a good section on troubleshooting power problems: http://elinux.org/R-Pi_Troubleshooting#Troubleshooting_power_problems
    0 Former Member over 11 years ago in reply to johnbeetem
    Got an adapter specifically for my Pi. I think it's a config setting. I'm think I may just use my TV and not my monitor. I'm starting to run in circles.
    I would set the output to a lower resolution to see if the problems still occurs and maybe check your cables are not introducing interference from other power cables etc
