Raspberry Pi Forum DarkIce: AlsaDspSource.cpp:265: Input/output error [0]
  • Replies 11 replies
  • Answers 2 answers
  • Subscribers 706 subscribers
  • Views 2900 views
  • raspeberry_pi_accessories
I try to build a streaming device with mij raspberry pi and wolfson audio card using darkice.
First i have installed the 2014-01-07-wheezy-raspbianW.zip image in the way
Leigh Davies had adviced. The next step i have installed darkice: Live mp3 streaming from audio-in with DarkIce and Icecast2 on Raspberry Pi
If i try to start darkice -c /etc/darkice.cfg i get the message after about 5 seconds: AlsaDspSource.cpp:265: Input/output error [0]
darkice.cfg:
# sample DarkIce configuration file, edit for your needs before using
# see the darkice.cfg man page for details
# this section describes general aspects of the live streaming session
[general]
duration        = 60        # duration of encoding, in seconds. 0 means forever
bufferSecs      = 5         # size of internal slip buffer, in seconds
reconnect       = yes       # reconnect to the server(s) if disconnected
# this section describes the audio input that will be streamed
[input]
device          = hw:0,0  # OSS DSP soundcard device for the audio input
sampleRate      = 44100     # sample rate in Hz. try 11025, 22050 or 44100
bitsPerSample   = 16        # bits per sample. try 16
channel         = 2         # channels. 1 = mono, 2 = stereo
# this section describes a streaming connection to an IceCast2 server
# there may be up to 8 of these sections, named [icecast2-0] ... [icecast2-7]
# these can be mixed with [icecast-x] and [shoutcast-x] sections
[icecast2-0]
bitrateMode     = abr       # average bit rate
format          = vorbis    # format of the stream: ogg vorbis
bitrate         = 96        # bitrate of the stream sent to the server
server          = www.double-u.nl        # host name of the server
port            = 8000      # port of the IceCast2 server, usually 8000
password        = *******  # source password to the IceCast2 server
mountPoint      = sample96  # mount point of this stream on the IceCast2 server
name            = DarkIce trial     # name of the stream
description     = This is only a trial     # description of the stream
url             = http://www.yourserver.com       # URL related to the stream
genre           = my own    # genre of the stream
Kind regardz, Wessel Overdijk
  • benip
    0 benip over 8 years ago
    Hello, I have this error message
    after setting up my hifiberry digi+ i/o board with darkice and a PI3:
    Using config file: /etc/darkice.cfg
    Using ALSA DSP input device: plughw:0,0
    Using POSIX real-time scheduling, priority 4
    Using aacplus codec
    what does it mean?  How to solve the problem ?
    I followed this configuration
    for the install of the hifiberry board:
    sudo nano /boot/config.txt
    dtoverlay = hifiberry-digi
    # Enable audio (loads snd_bcm2835)
    dtoverlay=hifiberry-digi
    after restart, i have :
    **** Liste des Périphériques Matériels PLAYBACK ****
    carte 0: sndrpihifiberry [snd_rpi_hifiberry_digi], périphérique 0: HifiBerry Digi HiFi wm8804-spdif-0 []
    Sous-périphériques: 1/1
    Sous-périphérique #0: subdevice #0
    sudo nano /etc/asound.conf
    pcm.!default {
    type hw card 0
    ctl.!default {
    type hw card 0
    My config with darkice is :
    [general]
    duration = 0 # duration of encoding, in seconds. 0 means forever
    [input]
    # device = /dev/dsp # OSS DSP soundcard device for the audio input
    device = plughw:0,0 # OSS DSP soundcard device for the audio input
    # this section describes a streaming connection to a ShoutCast server
    # there may be up to 8 of these sections, named [shoutcast-0] ... [shoutcast-7]
    # these can be mixed with [icecast-x] and [icecast2-x] sections
    [shoutcast-0]
    bitrateMode = vbr # average bit rate
    format = mp3 # format of the stream: ogg vorbis
    bitrate = 88 # bitrate of the stream sent to the server
    quality = 0.5 # encoding quality
    server = myip
    port = myport # source port of the ShoutCast server, usually 8001
    password = mypass # source password to the ShoutCast server
    name =  test darkice
    public = no # advertise this stream?
    irc = irc.yourserver.com
    # IRC info related to the stream
    aim = aim here # AIM info related to the stream
    icq = I see you too
    # ICQ info related to the stream
    Thanks for your answer
    best regards
    Ben
