Raspberry Pi Forum DarkIce: AlsaDspSource.cpp:265: Input/output error [0]
  • Replies 11 replies
  • Answers 2 answers
  • Subscribers 706 subscribers
  • Views 2890 views
  • raspeberry_pi_accessories
I try to build a streaming device with mij raspberry pi and wolfson audio card using darkice.
First i have installed the 2014-01-07-wheezy-raspbianW.zip image in the way
Leigh Davies had adviced. The next step i have installed darkice: Live mp3 streaming from audio-in with DarkIce and Icecast2 on Raspberry Pi
If i try to start darkice -c /etc/darkice.cfg i get the message after about 5 seconds: AlsaDspSource.cpp:265: Input/output error [0]
darkice.cfg:
# sample DarkIce configuration file, edit for your needs before using
# see the darkice.cfg man page for details
# this section describes general aspects of the live streaming session
[general]
duration        = 60        # duration of encoding, in seconds. 0 means forever
bufferSecs      = 5         # size of internal slip buffer, in seconds
reconnect       = yes       # reconnect to the server(s) if disconnected
# this section describes the audio input that will be streamed
[input]
device          = hw:0,0  # OSS DSP soundcard device for the audio input
sampleRate      = 44100     # sample rate in Hz. try 11025, 22050 or 44100
bitsPerSample   = 16        # bits per sample. try 16
channel         = 2         # channels. 1 = mono, 2 = stereo
# this section describes a streaming connection to an IceCast2 server
# there may be up to 8 of these sections, named [icecast2-0] ... [icecast2-7]
# these can be mixed with [icecast-x] and [shoutcast-x] sections
[icecast2-0]
bitrateMode     = abr       # average bit rate
format          = vorbis    # format of the stream: ogg vorbis
bitrate         = 96        # bitrate of the stream sent to the server
server          = www.double-u.nl        # host name of the server
port            = 8000      # port of the IceCast2 server, usually 8000
password        = *******  # source password to the IceCast2 server
mountPoint      = sample96  # mount point of this stream on the IceCast2 server
name            = DarkIce trial     # name of the stream
description     = This is only a trial     # description of the stream
url             = http://www.yourserver.com       # URL related to the stream
genre           = my own    # genre of the stream
Kind regardz, Wessel Overdijk
    Input/output error usually means that Darkice doesn't receive anything from the sound card.
    You have to run the appropriate Record_from... script first.
    I've found that an extra
    amixer -Dhw:0 cset name='AIF Playback Switch' on
    can be needed too.
    Ragnar
    unfortunately, the same error occured. Is it necessary to use an external power supply:
    sudo darkice -v9 -c /etc/darkice.cfg
    DarkIce 1.0 live audio streamer, http://code.google.com/p/darkice/
    Copyright (c) 2000-2007, Tyrell Hungary, http://tyrell.hu/
    Copyright (c) 2008-2010, Akos Maroy and Rafael Diniz
    This is free software, and you are welcome to redistribute it
    under the terms of The GNU General Public License version 3 or
    any later version.
    Using config file: /etc/darkice.cfg
    01-Apr-2014 13:49:47 Using ALSA DSP input device: hw:0,0
    01-Apr-2014 13:49:47 encoding
    01-Apr-2014 13:49:47 scheduler high priority 99
    01-Apr-2014 13:49:47 Using POSIX real-time scheduling, priority 98
    01-Apr-2014 13:49:48 MultiThreadedConnector :: tranfer, bytes 10584000
    01-Apr-2014 13:49:48 MultiThreadedConnector :: ThreadData :: threadFunction, was (thread, priority, type):  0x1ecc318 98 SCHED_FIFO
    01-Apr-2014 13:49:48 MultiThreadedConnector :: ThreadData :: threadFunction, now is (thread, priority, type):  0x1ecc318 1 SCHED_FIFO
    You config file seems fine. I only changed the server name and  password and it streams just fine to my Icecast server.
    An external power supply should only be necessary if you want to use the speaker amplifier on the card.
    Which input is it you're trying to stream?
    Ragnar
    I'm trying to use the line-in.
    Kind regardz, Wessel.
    Hmm...
    What is the output of these commands?
    amixer -Dhw:0 cget name='AIF1TX1 Input 1' | tail -1
    amixer -Dhw:0 cget name='AIF1TX2 Input 1' | tail -1
    They should return "values=11" and "values=12"
    Ragnar
    Oeps, not good:
    : values=0
    : values=0
    No, not good image
    values=0 means Input=none
    That would indicate that the use case script Record_from_lineIn.sh has not been run.
    Run that script and check again. If you get 11 and 12, try to stream.
    These are the commands in the script:
    amixer -Dhw:0 cset name='IN3L Volume' 8
    amixer -Dhw:0 cset name='IN3R Volume' 8
    amixer -Dhw:0 cset name='IN3 High Performance Switch' on
    amixer -Dhw:0 cset name='IN3L Digital Volume' 128
    amixer -Dhw:0 cset name='IN3R Digital Volume' 128
    amixer -Dhw:0 cset name='AIF1TX1 Input 1' IN3L
    amixer -Dhw:0 cset name='AIF1TX1 Input 1 Volume' 32
    amixer -Dhw:0 cset name='AIF1TX2 Input 1' IN3R
    amixer -Dhw:0 cset name='AIF1TX2 Input 1 Volume' 32
    Ragnar
    Thanks a lot Ragnar, that was the missing part! image
    Greetings, Wessel Overdijk
  • benip
    0 benip over 8 years ago in reply to e14 Contributor
    Hello, I have this error message
    after setting up my hifiberry digi+ i/o board with darkice and a PI3:
    Using ALSA DSP input device: plughw:0,0
    Using POSIX real-time scheduling, priority 4
    Using aacplus codec
    what does it mean?  How to solve the problem ?
    I followed this configuration
    for the install of the hifiberry board:
    sudo nano /boot/config.txt
    dtoverlay = hifiberry-digi
    # Enable audio (loads snd_bcm2835)
    dtoverlay=hifiberry-digi
    after restart, i have :
    **** Liste des Périphériques Matériels PLAYBACK ****
    carte 0: sndrpihifiberry [snd_rpi_hifiberry_digi], périphérique 0: HifiBerry Digi HiFi wm8804-spdif-0 []
    Sous-périphériques: 1/1
    Sous-périphérique #0: subdevice #0
    sudo nano /etc/asound.conf
    pcm.!default {
    type hw card 0
    ctl.!default {
    type hw card 0
    My config with darkice is :
    [general]
    duration = 0 # duration of encoding, in seconds. 0 means forever
    [input]
    # device = /dev/dsp # OSS DSP soundcard device for the audio input
    device = plughw:0,0 # OSS DSP soundcard device for the audio input
    # this section describes a streaming connection to a ShoutCast server
    # there may be up to 8 of these sections, named [shoutcast-0] ... [shoutcast-7]
    # these can be mixed with [icecast-x] and [icecast2-x] sections
    [shoutcast-0]
    bitrateMode = vbr # average bit rate
    format = mp3 # format of the stream: ogg vorbis
    bitrate = 88 # bitrate of the stream sent to the server
    quality = 0.5 # encoding quality
    server = myip
    port = myport # source port of the ShoutCast server, usually 8001
    password = mypass # source password to the ShoutCast server
    name =  test darkice
    public = no # advertise this stream?
    irc = irc.yourserver.com
    # IRC info related to the stream
    aim = aim here # AIM info related to the stream
    icq = I see you too
    # ICQ info related to the stream
    Thanks for your answer
    best regards
    Ben
