Raspberry Pi Forum Maximum and Minimum thermometer
  • Replies 7 replies
  • Subscribers 686 subscribers
  • Views 1609 views
Hi to Everyone this is my very first question in the forum. I hope that I am in the right area to put my question.
I wonder if it's possible to construct a maximum and minimum thermometer using the Raspberry Pi, if so what is required as regards hard ware etc and skill level of course?
My thanks in advance.
  • iagorubio
    0 iagorubio over 11 years ago
    If you mean a thermostat, yes it's possible.
    I use usually the DS1620 Maxim digital thermometer as it have thermostat but it's a bit complex.
    The 1-Wire DS18B20 is much easier and there is a lot of work done to make it work with raspberry.
    Look here for more information
    Raspberry Pi 1- Wire Digital Thermometer Sensor | Raspberry Pi Spy
    0 Former Member over 11 years ago in reply to iagorubio
    Many thanks for your prompt reply.
    I had in mind something that would display the maximum and minimum, with the sensor outside and the Raspberry Pi on the window sill.
    Thanks once again
  • johnbeetem
    0 johnbeetem over 11 years ago
    Here's another project using the DS18B20 1-Wire temperature sensor with RasPi: https://learn.adafruit.com/large-pi-based-thermometer-and-clock/
  • Problemchild
    0 Problemchild over 11 years ago in reply to johnbeetem
    Yep follow John's idea with the Dallas 1 wire sensor this is already well supported so you will find drivers already about making your life much easier.
    You can then read the values from the sensor using say a Python program or what ever language you are experienced in
  • Robert Peter Oakes
    0 Robert Peter Oakes over 11 years ago
    and if you want to have a small LCD display to keep the power lower then this would be relatively easy to add
    http://canada.newark.com/adafruit-industries/1115/blue-white-16x2-lcd-keypad-kit/dp/52W9087
    I'm using the 18B20 with the Pi (with Raspbian) at the moment: very simple to interface and to use.  This bit of PHP works to get min/max readings (the 28-000.... file corresponds to the 1-bit identifier of the temperature sensor):
    <?php
    //Init sensors if necessary
    $dir=scandir("/sys/bus");
    if(!array_search("w1",$dir)){ // devices not there yet
        exec("modprobe w1-gpio");
        exec("modprobe w1-therm");
    $device="/sys/bus/w1/devices/28-000005a1fbf8/w1_slave";
    $highest=-1000;
    $lowest=1000;
    while(true){
        $lines=explode("\n",file_get_contents($device));
        if( preg_match_all("/YES/",$lines[0],$matches) ){   // CRC is good
            if( preg_match_all("/t=(\d+)/",$lines[1],$matches) ){
                $pf = round( $matches[1][0] / 100 )/10;
                $highest = $pf>$highest? $pf:$highest;
                $lowest = $pf<$lowest? $pf:$lowest;
                printf("Highest = $highest, Lowest = $lowest\n");
        sleep(1);  //wait until next reading
    0 Former Member over 11 years ago in reply to Former Member
    Many, many thanks for all your replies quite a lot to take in I'll read up on all of the links. Thanks once again
