Raspberry Pi Forum Where can I find 3D Engineering drawing of Wolfson Audio Card for designing our enclosure.
  • Subscribers 707 subscribers
  • Views 665 views
  • wolson
  • audio
  • 3d
  • enclosure
We are planning to integrate Wolfson Audio Card with our RPi based product. To enable us to design an enclosure we are looking for a 3D engineering drawing. Please lets us know where we can find the 3D drawing.
  • dougiel
    0 dougiel over 12 years ago
    I suspect you'll need to contact Element14's tech support group directly (through Feedback and Support). There's no evidence of the physical card layout and dimensions being published anywhere. There's lots of docs for the audio processor (313 pages), there's a schematic (7 pages) but those are not the item you require.
  • Problemchild
    0 Problemchild over 12 years ago
    I personally always try and buy one of what ever I'm enclosing as much as that even if they provide and engineering drawing the chances are that something is not quite right or you miss something in how it all fit's together. If you have the real device in your hand you can feel fairly certain that it will all fit before the customers have a blue fit at you .
  • cstanton
    0 cstanton over 12 years ago
    There currently isn't a layout diagram with exact measurements available.
    Do you want general measurements of the board (as in dimensions of the outer areas) or exact placements and measurements to them and around them (a PCB layout with measurements) ?
    Practically I have a pair of calipers and a Wolfson Audio Card, so I could take measurements; but then you're relying on the accuracy of my cheap bought calipers and my hand to eye co-ordination. If that isn't acceptable I would suggest buying a Wolfson Audio Card and then measuring it.
    0 e14 Contributor over 12 years ago in reply to cstanton
    I too purchased a Wolfson card
    Designing a tight enclosure with fan, led, switches and battery backup, it is easier for industrial designer to import into their design the 3D of the board enabling tight and perfect fit. I will check with Element14 and see if they have created the 3D drawing.
