Raspberry Pi Forum Wolfson Audio Card and alsamixer
  • Subscribers 678 subscribers
  • Views 672 views
  • wolfson
  • wm5102
  • raspeberry_pi_accessories
hi,
with the command
alsamixer -c0
it is possible to get access to all paramaters of the card. Is there any documentation available about configuring these parameters (e.g. the use of the 5-band-equaliser)?
  • soundcamp
    0 soundcamp over 11 years ago
    The command 'alsamixer' gives access to a GUI with sliders for the Mic Inputs, Equalizers, etc. They don't seem to be active for the Wolfson.
    Does anybody know how to set them up?
    Grant
  • Marki555
    0 Marki555 over 11 years ago in reply to soundcamp
    I don't have the card yet, but I hope all settings are exposed in the alsa mixer. The names of controls are pretty the same as those in datasheet, so it is easy to guess what they do.
    For some functions you have to first enable them (*_ENA), for some (like EQ) you need to know the coefficients and you need to setup the audio path to actually use it.
    For the EQ, check my blog post Wolfson audio paths & how to use EQ and LHPF
  • royleith
    0 royleith over 10 years ago in reply to soundcamp
    They work for me. You need to use F6 to select the hw:0 device or the snd_rpi_wsp device. The real problem is that there are well over 400 controls and it is not a realistic option for regular use. Ragnar's scripts are the best bet, atm.
    I am half way through writing a Python based simple mixer based on the alsamixer and the amixer programs. It will include the white noise and tone generators as fixed sources, but the current version misses the compressors, high pass and low pass filters and the equalisers.
    0 Former Member over 10 years ago in reply to royleith
    I build a kernel (make last about 15 hours). After cp the kernel.img in de boot dir. I was able  to manupilate alsamixer only once the wolfson audio card. After a reboot I only see the bcm2835 audio . F6 don't show no the wolfson card.
    Do I have to configure more things??
    0 Former Member over 10 years ago in reply to Former Member
    Give this a try ...realtime kernel 3.12.33 as easy to install deb package
    https://blog.georgmill.de/2015/02/18/update-for-wolfson-audio-card-on-raspberry-pi/
