Raspberry Pi Forum Why the Wolfson Audio Card doesn't work after Raspbian update/upgrade?
  • Subscribers 706 subscribers
  • Views 446 views
  • problem
  • wolfson:
  • if
  • raspbian
  • upgrade
I copied the SD image given by Wolfson to run the audio card and it worked very good. Because of my project (using mysql connections) I had to update and upgrade my raspbian, and then I cannot record or play any file. I know that Wolfson and Element 14 had to hack the normal raspbian version, and I suppose that upgrading it restores the hacked files, so how can I make it work again (without rewritting the SD card)?
  • packetgeek
    0 packetgeek over 12 years ago
    It's because the driver modules aren't automatically rebuilt for the new kernel.  You need to step through the process again.
    - Tim
    0 e14 Contributor over 12 years ago in reply to packetgeek
    Hi Tim, thanks for your answer. The problem is that my program needs mysql access and I cannot install it if I don't update/upgrade the raspbian. Do you have any idea how can I install mysql library? because the usual command "apt-get install mysql-client" doesn't work unless I upgrade the kernel? Tks. Xavier
    That sounds weird... I just installed mysql-client without any problems, using the same old kernel (3.10.25) I have always used with the Wolfson card.
    I just did an "apt-get update" to refresh the list of repository mirrors, and then "apt-get install mysql-client".
    In what way does "apt-get install mysql-client" not work for you? Error messages?
    Ragnar
    Hi Ragnar, I thought that after the "update" I always had to execute the "upgrade" instruction, so that's why I didn't try to just "update" and then install "mysql-client". With your method I could install "mysql-client" and use the wolfson card too. Thank you!
