Raspberry Pi Forum What should I use to power my Raspberry Pi?
  • Replies 17 replies
  • Answers 2 answers
  • Subscribers 710 subscribers
  • Views 3100 views
I was recently given a Raspberry Pi model B and i wanted to know if it is safe to power it with Samsung Galaxy S4 wall adapter. On the back of the adapter it says it outputs 5V and 2A. I read somewhere that I should power it with 700 - 1200 mA and 5V. Will this adapter be okay to use?
  • Problemchild
    0 Problemchild over 12 years ago in reply to simon.monk
    Good one Simon it shows that even with a WIFI the PI doesn't need much more than 500ma  except if you have a big keyboard or mouse .
    I  did a thermal photo of an RPI  booting playing videos
    Hope you find it interesting
  • johnbeetem
    0 johnbeetem over 12 years ago in reply to Problemchild
    Interesting that the LAN9512 is still such a hot spot with a 2.0 PCB.  The thermal profile looks a lot like a 1.0 PCB where the LAN9512 was doing all the 1.8V regulation.  I see a little heat on your 1.8V regulator, but not much.
  • Robert Peter Oakes
    0 Robert Peter Oakes over 12 years ago
    yes, in my blog entry analysing the power consumption, just a simple keyboard, mouse and WIFI took the amps up to just under 700mA, this is the point where the resettable fuse starts to warm up and potentially cause you issues.
  • Problemchild
    0 Problemchild over 12 years ago in reply to johnbeetem
    Yes I pointed that out in my description on YT, the Chip isn't even transmitting any data!!
  • rew
    0 rew over 12 years ago in reply to Problemchild
    3.3V on the 'pi is not used for anything much. Except as the power to the LAN chip. Generally speaking about half the power of the 'pi is consumed in the LAN chip. It is an inefficient chip, which is powered in an inefficient way. That's the way it is. If you're on  a power-budget, get a model A.
    I've been measuring the I-V curves of powersupplies yesterday. Some 500mA adapters only manage 350mA. Others achieve up to 150% of their rated current. One adapter ended up dipping from the "normal" 5.3V to below 4V every 20ms when it was loaded. 20ms? Yes. That must mean they used only one diode instead of four, and chose a "too small" capacitor. Opening it up: indeed only one diode. (The "dips to 4V" means the 'pi will crash).
    0 Robert Peter Oakes over 12 years ago in reply to rew
    Any power adapter putting out 5.3V nominal should be thrown out, the TTL logic thresholds and industry standard for 5V devices has been 5% for a very long time, thats 4.75 to 5.25, 5.25 being the upper limit, not the nominal voltage. You can risk your device running above that
    This whole thing of going to a 5.25 V wall wart is very misleading and should be avoided, it is either a bad adapter or more lightly a bad USB cable. A couple of us in the forum have performed some extensive testing in this area , see http://www.thebreadboard.ca/?p=235
    Peter
  • D_Hersey
    0 D_Hersey over 12 years ago
    Generalizing outside of RPi, this is what makes the silicon-gate logic families, like 40XX, 40xxUB, 45XX and 7CXXX still applicable today, sometimes, despite their relatively low speed.  Often they can run off batteries without regulation, because their supply range is so great.
