Raspberry Pi Forum Wolfson Audio Card as guitar effect unit
  • Subscribers 702 subscribers
  • Views 770 views
  • guitar_effect
  • audio_card
  • raspeberry_pi_accessories
does anybody know, if it would be possible to use the Audio Card as a guitar effect unit?
We are a group of three students, trying to achieve this project at our university. So far, we thought it should be possible after reading the datasheet and wanted to test it. The problem is, that we don't have the time to write our own drivers, so we tried to understand how the existing one works in c-files we found but were not able to comprehend.
Is there any documentaition available which explains for example how to route a signal from the line in jack to the line out jack?
-Ingo
    It is possible but keep in mind that you will need a preamp stage (I am designing one at the moment) for instrument level to line level. Also if you want to drive a guitar amp then the output stage must be adjusted too (line level to instrument level - I'm not sure of this information).
    Then it's just a matter of using the right configuration (rt-kernel - system tweaking (limits.conf)) & the right software (in my case pure data, there's also guitarix).
    The good news is that Wolfson is very good at low latency when the system is configured correctly. I can get down to 4ms!! when patching the line in to line out directly using pure data / alsa. I didn't have any luck with jackd for the moment (xruns...).
    Cheers!
    that really is good news, thanks for your answer!
    We tried to get as far as possible with pure data, but kept struggling to comprehend existing code. Our next step will be to find out more about the right configuration you have mentioned and alsa. Also I will give guitarix a try.
    - Ingo
    If you're going with Pure Data, you should use this version (vanilla):
    http://msp.ucsd.edu/Software/pd-0.45-4.rpi.tar.gz
    Start it like this (I don't mind about security):
    sudo pd -rt -alsa -audiodev 1 -r 44100 -audiobuf 8 -channels 2 -nogui -stderr -open YOURPATCH.pd
    Adjust the -audiobuf so that you don't have glitches, errors.
    I am able to get as low as -audiobuf 3 with a simple [adc~] - [dac~] patch.
    Cheers
