Raspberry Pi Forum dynamic DNS for 3G USB modem raspberry pi
  • Replies 16 replies
  • Subscribers 707 subscribers
  • Views 3042 views
  • dns
  • raspberrypi
  • 3g
  • usbmodem
bhuvan
bhuvan over 12 years ago
Hi guys
I have a 3G USB modem (ZTE Mf 70) . i want to access a IP camera on a particular port from the pi from anywhere in the world.
I wanted the pi to use the same Ip address everytime on bootup. I thought of using a hostname which would map to the IP address everytime (even if Ip address changes)
I wanted to know if installing a dynamic dns application on the pi, would help to achieve this.
or else, is there any other way of doing this ??
  • rew
    0 rew over 12 years ago
    Your provider (in this case the 3G one) will assign you an IP address. When your location is static, say on a cable or ADSL connection, they may decide to give you the same IP address every time your computer/modem starts up. But they could also decide: we need less IP addresses because half the people have their modem turned off. So then they have to cycle through the IP addresses to serivice those that are online.
    Anyway, with 3G, you are likely to get a new/changing IP address every time your connection starts up. Or maybe even when you switch towers (but I doubt that:  they should make arrangements to fix that if it happens).
    Anyway, if you install something like "dyndns", you will be able to refer to the 'pi as <something>.dyndns.org, which will resolve to whatever IP address you got this time.
    However, I've also seen 3G providers that use "internal" IP addresses on their network. In that case instead of assigning an externally visible IP address to every "phone", they use an "internal only" IP address range, that only works within their own network. And when packets from your 'pi go out on the internet they are quickly translated to some public IP address. Return traffic is similarly modified to go back to your phone. This way they can save enormously on the number of public IP addresses that they need. But it means you cannot reach the internal IP addresses at all from the outside. (which is usually a bonus, because it prevents remote network attacks!).
    So, if you do a quick "ifconfig" and show us the results we can look up if your 3G modem gets a public IP address.
  • bhuvan
    0 bhuvan over 12 years ago in reply to rew
    Thank you for your reply .
    rew
    When I do ifconfig on the pi, the Ip address I get is something like 192.168.0.100, which is an internal address I guess. Will dydns still work ?
    What I am trying to do is use motion camera software on the pi to broadcast a video stream onto a certain IP address and port number.
    I want to be able to use the same Ip address every-time (reboot, new connection, etc).
  • rew
    0 rew over 12 years ago in reply to bhuvan
    Yup! That's an internal address which is not reachable from the outside.
    I personally own a "server" on the internet. For cases like this I will have the 'pi call out to the server which is similar to loading a website. Thus the provider will have to make that "work", otherwise nobody would be able to use the internet.
    Then I create a "tunnel", so that from the server I can reach the 'pi. Next some trickery with ports and stuff and I'd be able to reach the 'pi from around the globe.
    If you don't have your own server, I'm not sure if you'd be able to find a low-cost provider for such a service. I've searched for "free tunnel service" for a few minutes now, and the services that come up do something close to the reverse of what you want.... :-(
  • Robert Peter Oakes
    0 Robert Peter Oakes over 12 years ago in reply to bhuvan
    you can also have the Router (If you have Admin access to it) do the dydns for you, it knows the outside IP address and can manage the service for you in most cases (Older routers may not have this feature, check the user manual for details), then you can forward a socket to the internally attached PI.
    A socket is the PORT number and is a bit like a room number where the IP address is the house number  http://en.wikipedia.org/wiki/Network_socket
    it is a lot less complicated than it sounds.
    Is the PI going to be located in your home network and your wanting to access it via a mobile device connected to the internet ?, or is the PI and camera going to be located elsewhere ?
    Peter
  • rew
    0 rew over 12 years ago in reply to Robert Peter Oakes
    Peter, I thought Bhuvan has a 3G wireless modem. So his GSM provider has the "router" you're talking about....
    0 Robert Peter Oakes over 12 years ago in reply to rew
    he does mention the modem but also states he wants to access it from anywhere on the internet, so im not sure which part is stationary and which is moving, I also dont know bhuvan knowledge level so felt the need to ask a few more probing questions
  • bhuvan
    0 bhuvan over 12 years ago in reply to Robert Peter Oakes
    rew and Robert Peter Oakes
    Thank you guys for your response.
    I think mr. Roger you are talking about reverse SSH ??? Can i get my camera working remotely using reverse ssh ?? If so, can you please let me know how to do so ??
    Mr, peter, the modem (USB 3G) will be inside a vehicle (car). i want to be able to monitor the video feed inside from any place in the world on a laptop/pc/tablet.
    I plan to use motion software to do so.
    Also, when I do ifconfig on pi, I get a local address like 192.168.0.100, nut when I open my browser and open whatsmyip, the IP is some public IP 74.xx.xx.xx. There is NAT clearly happening here.
    By using reverse ssh, can i view the video in the vehicle (connected to a 3G USB dongle) from anywhere in the world ??
  • rew
    [Apparently I didn't hit "send" yesterday]
    However, 3G providers mostly use "internal" IP addresses on their network. In that case instead of assigning an externally visible IP address to every "phone", they use an "internal only" IP address range, that only works within their own network. And when packets from your 'pi go out on the internet they are quickly translated to some public IP address. Return traffic is similarly modified to go back to your phone. This way they can save enormously on the number of public IP addresses that they need. But it means you cannot reach the internal IP addresses at all from the outside. (which is usually a bonus, because it prevents outside hackers from trying to hack your phone).
    Anyway, what you need is a VPN, then you can reach the 'pi from the VPN. And the next step would be to make that accessable for /you/ from "anywhere you want". But as I said: I'm not aware of public services that would let you do that.
  • bhuvan
    rewRobert Peter Oakes
    But as you mentioned before, will reverse ssh work??
    as I have a server which I think I can create a tunnel to.
  • rew
    I don't know what you mean with "reverse ssh".
    Hmm. SSH has "port forwarding". Yeah, that would work. From the 'pi do:
    • ssh server -R server:8080:localhost:80 command.
    This will redirect port 8080 on the server to port 80 (the web server) on the 'pi. Everybody will now be able to connect to the 'pi, so be careful. Maybe you want some kind of access control.
    That should work. I'm not immediately sure what command to specify (sleep 100000000 should work for a while), or if there is an option to do without a command.
