Raspberry Pi Forum Using Raspberry Pi + Wolfson Audio Card to create an audio delay solution?
  • Answers 2 answers
  • Subscribers 703 subscribers
  • Views 708 views
  • raspeberry_pi_accessories
spoonsphere
spoonsphere over 12 years ago
Hello!
I'm curious if anyone can provide direction for using The Raspberry Pi with the Wolfson Audio Card as an audio delay unit.
I would like to take line level audio in, specify a delay, and send line level audio out.
Thanks!
    HI,
    See my post here:
    http://www.element14.com/community/thread/35033/l/wolfson-audio-card-as-guitar-effect-unit
    Using Pure Data to make the delay (G01.delay.pd (replacing the tabplay~ by [adc~])).
    You don't need the preamp, since your signal is line in / line out.
    Cheers
  • spoonsphere
    0 spoonsphere over 12 years ago in reply to e14 Contributor
    Thank you, Pat! I will take a look at PD.
    Question for you about the accuracy of the delay you specify using PD - do you get accurate results, or do you have to adjust the delay value to compensate for latency? Also, how robust is the PD solution? Would you use it in a live event setting?
    Thank you again!
    0 e14 Contributor over 12 years ago in reply to spoonsphere
    HI,
    This solution can be sample accurate AFAIK. There's a PD patch to calculate the round-trip latency of you setup:
    Pure Data Patch Repository
    PD is rock solide, it has been used in live setting and installations (running for many many months).<
    Let me know if you are facing problems with it.
    Cheers
