Raspberry Pi Forum Wolfson recording and encoding at same time...
  • Subscribers 696 subscribers
  • Views 273 views
  • wolfson
  • audio
  • alsa
  • recording
  • raspeberry_pi_accessories
rec9140
rec9140 over 11 years ago
I use some software to capture audio and send it along to another server in MP3 format... working great... what I need to be able to do is
ENCODE this stream
AND
Then based on some even triggers RECORD one of the inputs under Python (if I can find a library that does it in MP3 format) or via BASH if I have to called from a Python program ie: arecord (options) myaudio.wav then feed to LAME or ffmpeg to turn it into MP3 (or again if there is a direct way to do it via Python or BASH with out the ffmpeg/LAME layer... I am all ears...)...
BUT
Trying this on the test setup results in:
trying to record either plugin via arecord or anything else seems to be "blocked?"
[code]
arecord -d:plug:plug_onboard_right -d 20 -r 48000 -c 1 -f S32_LE Test.wav
arecord: main:682: audio open error: Device or resource busy
[/code]
Doing this on a "DESKTOP" under Kubuntu works.. same plugins... the same software is running on the desktop, and it will record the plugin in, or hw:0,0 with out issue.
I thought that maybe having another DSNOOP might solve it.. but that doesn't seem to solve it either, same error.
Any ideas??? Comments, Suggestions, Buehler?
.asoundrc below for reference....
[code]
pcm.wolfson_pi_soundcard {
    type hw
    card sndrpiwsp
    device 0
pcm.softvol {
    type            softvol
    slave {
        pcm         "wolfson_pi_soundcard"
    control {
        name        "Master"
        card        0
pcm.onboard{
    type hw
    card 0
ctl.onboard {
    type hw
    card 0
### Dsnoop both channels
pcm.dsnoop_onboard {
    type dsnoop
    ipc_key 32
    slave {
        pcm "onboard"
        channels 2
        period_size 320
        rate 48000
        buffer_size 8192
        format S32_LE
    bindings {
        0 0
        1 1
### Dsnoop splited channels
pcm.onboard_left {
     type dsnoop
     ipc_key 32
     slave {
         pcm "onboard"
         channels 2
     bindings.0  0
pcm.onboard_right {
     type dsnoop
     ipc_key 32
     slave {
         pcm "onboard"
         channels 2
     bindings.0  1
### PLUGS ##
### used with encoders
### device = plug:plug_onboard_left
pcm.plug_onboard_left{
        type route
        slave.pcm "onboard_left"
        slave.channels 1
        ttable.0.0 1
pcm.plug_onboard_right{
        type route
        slave.pcm "onboard_right"
        slave.channels 1
        ttable.0.0 1
pcm.plug_onboard_RECCHAN{
        type route
        slave.channels 1
        ttable.0.0 1
[/code]
