Raspberry Pi Forum Creating custom USB Hub for custom Pi case
  • Replies 12 replies
  • Answers 2 answers
  • Subscribers 707 subscribers
  • Views 1892 views
Sorry if this is the wrong place...
I want to make a custom media center case for my Raspberry Pi that will house the Pi and a USB Hub (maybe a HDD but unlikely).
I'd prefer it if all the cables are kept on the inside of the case, and all the ports for the case are at the back.
After searching a while for USB Hubs, it soon dawned on me that no USB Hub has the power port and usb ports on the same side, with the connector (so you can connect it to the Pi) on the inside.
And it's also unlikely that I will ever find one as it would be a weird design. So, I pretty much have no choice than to either modify an existing USB Hub so it matches my needs, or create my own relatively from scratch.
It would have to be a powered USB Hub so that it can power the Pi aswell.
The problem is, I have never done anything close to this before, so I am completely clueless as to where to start..
So, I was wondering if anyone could suggest some stuff I read/watch so that I can give it a go? Or perhaps an already existing USB Hub that would be relatively easy to modify to my needs.
  • gregoryfenton
    0 gregoryfenton over 12 years ago
    Hi Joe
    Do you have access to either a 3D printer or a laser cutter? If so designing a custom case would be quite straightforward.
    If you don't have access, is there a hackerspace or makerspace near you? The guys in there will doubtless have one or both of the above, and would be happy to show you how to customise your own.
    Greg
    0 e14 Contributor over 12 years ago in reply to gregoryfenton
    I have access to 3D printers, but my problem is creating or finding a USB Hub that will fit in with the case. (Power and USB ports on the same side with the port you use to connect to the Pi on the inside)
    I've looked around and it seems my only option will be to make one, but I have no experience in this, so wondered if anyone might be able to help/get me started.
  • gregoryfenton
    0 gregoryfenton over 12 years ago in reply to e14 Contributor
    A slight misunderstanding there, but again this is not unsurmountable.
    You could take a standard existing hub, remove the ports and power supply connectors and mount new ones on a PCB with the orientation as you wish and make a new case to suit.
    Hmm, that simple huh? Thanks for help, I'll have to look into it.
  • kidiccurus
    0 kidiccurus over 12 years ago in reply to e14 Contributor
    No need for for a PCB. Regular pegboard glued in place would be fine. Just wire everything to the points on the original board. Keep the wires as short as possible to reduce interference.
    How would I go about designing a PCB for a Powered USB Hub?
    I came across this very thing on kickstarter: https://www.kickstarter.com/projects/10la/raspiado-the-usb-hub-that-fits-your-raspberry-pi
    The Developer made a custom USB hub to fit on a Raspberry Pi. He probably has to fulfill his kickstarter pre-orders, but he'll most likely be selling them soon.
    That looks nice, unfortunately not what I am looking for.
    What I need is the USB ports and power port on the same side, but not the micro USB port so that it can connect to the Pi on the inside of my case and be powered from the outside.
    It seems as I would have to create it myself to achieve this, but I just need to work out how to design a PCB for a powered USB hub.
    0 michaelkellett over 12 years ago in reply to e14 Contributor
    I'm not quite sure what you are asking here. Is it that you don't know how to design any pcb or that you don't know how to design a USB hub ?
    If you haven't already designed a few pcbs this isn't the project to start with.
    Generic hubs are not that hard to design if you know how to do pcbs because the chip manufacturers publish reference designs.
    If you don't know how to design pcbs at all you need to get some practice in with something a bit simpler.
    If the Raspiado schematic is availability that would be a good place to get some pointers about hub design.
    0 e14 Contributor over 12 years ago in reply to michaelkellett
    I had someone to design it for me, but he just changed his mind.
    I'll have to look into designing them and start practicing.
