Raspberry Pi Forum Enocean Pi Layout/Pinout description???
  • Answers 2 answers
  • Subscribers 705 subscribers
  • Views 1681 views
  • enocean
  • raspberrypi
  • raspeberry_pi_accessories
vish
vish over 12 years ago
Hello all,
I'm looking for the pinout description of enocean pi module( EnOcean Pi: Transforms Raspberry Pi into a Wireless Gateway ). I want to design an addon board for my rPi which will hold enocean pi and a few other peripherals.
Is the RX TX and the power lines are the only lines enocean pi module uses? If so, whether a PCB design which feeds those lines( and power) from rPi to enocean module will work?
Thanks ahead,
vish
  • fvan
    0 fvan over 12 years ago
    I'm planning on doing the same, but schematic is obviously a must have first ...
    I believe ipv1 planned on removing the module to come up with one (IP Post 3: EnOcean Pi, Sensors and FHEM and the lost hours of sleep)
    Frederick
  • ipv1
    0 ipv1 over 12 years ago
    To my experience , 4pins have been used by the enocean pi.
    The 3.3v , gnd, UART txd and UART rxd. No reset or anything else.
    I am going to do something similar where I desolder the enocean pi header and use wires to jump them to the pi connector.
    Hope this help
    IP
    Please see the TCM310 user manual as this is what is on the EnOcean Pi board.
    http://www.enocean.com/en/enocean_modules/tcm-310/
    You will need TX/RX/GND/VCC/Reset connected
  • ipv1
    0 ipv1 over 12 years ago in reply to e14 Contributor
    I still think the reset pin is not connected to the RPi. Will have a positive answer by tomorrow.
  • vish
    0 vish over 12 years ago in reply to e14 Contributor
    When I checked also, RST is not connected. And in my module Pin18(GND) is also not connected to GND.
