Raspberry Pi Forum Help Please
  • Subscribers 678 subscribers
  • Views 545 views
  • help
  • pi
  • timer
  • raspberrypi
  • counter
Help Please
giusepperamos
giusepperamos over 11 years ago
I used the raspberry pi to supervise a motel room status. My code is working fine, but I need to restart the count at specific time every day. please help me with that.
here is my script in Python.
# Librerias
import MySQLdb
import time
import datetime
import sys
import subprocess
import re
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
GPIO.setup(7, GPIO.IN, pull_up_down=GPIO.PUD_UP)
# VARIABLES
input = GPIO.input(7)
rampa1 = 1
sucursal = ("Las Vegas")
ent = ("Entrada")
sal = ("Salida")
counts1 = 0
variable1 = 0
valorsalida = "*"
#Variables de Base de Datos
server = ("server")
DB = ("db")
password = ("password")
username = ("username")
# Prueba de coneccion a base de datos
# Ecuaciones
def emailerror():# Envio de Email en caso de error de coneccion
                import smtplib
                try:
                        SMTP_SERVER = 'smtp.gmail.com'
                        SMTP_PORT = 587
                        sender = 'pruebaraspberry@gmail.com'
                        recipient = 'aaguilar@agflosa.com, ramosgiuseppe@gmail.com'
                        subject = 'Error en conectar a la base de datos'
                        body = 'Revisar coneccion con el servidor de base de datos'
                        "Sends an e-mail to the specified recipient."
                        body = "" + body + ""
                        headers = ["From: " + sender,
                                          "Subject: " + subject,
                                           "To: " + recipient,
                                           "MIME-Version: 1.0",
                                           "Content-Type: text/html"]
                        headers = "\r\n".join(headers)
                        session = smtplib.SMTP("smtp.gmail.com",587)
                        session.ehlo()
                        session.starttls()
                        session.ehlo
                        session.login("pruebaraspberry@gmail.com","pepe2488")
                        session.sendmail(sender, recipient, headers + "\r\n\r\n" + body)
                        session.quit()
                        print("Revisar coneccion con el servidor")
                except:
                        print ("revise coneccion a internet")
def coneccionentrada():# Coneccion de Entrada
  try:
                conn = MySQLdb.connect(server,DB,password,username)
                conn.cursor().execute("INSERT INTO contador (Camiones, fecha, Tiempo, Rampa, Sucursal, EOS) VALUES (%s, %s, %s, %s, %s,%s)",
  (counts1, dateentrada, timeentrada, rampa1, sucursal, ent))
                print ("Datos de Entrada Enviados")
  except:
                print ("los datos no pudieron enviarse")
def coneccionsalida():# Coneccion de Salida
        try:
                conn.cursor().execute("INSERT INTO contador (Camiones, fecha, Tiempo, Rampa, Sucursal, EOS) VALUES (%s, %s, %s, %s, %s, %s)",
  (valorsalida, datesalida, timesalida, rampa1, sucursal, sal))
                print ("Datos de Salida Enviados")
        except:
# Inicio del Programa
try:# Prueba de Conneccion
        print ("Conectandose a la Base de Datos")
        print ("Conectado con el Servidor")
except:
    emailerror()
# Inicio de Loop
while (True):
# Entrada de Auto Habitacion  1 #
   GPIO.wait_for_edge(7,GPIO.FALLING)
   time.sleep(180)
   if (input == GPIO.LOW) and (variable1==0):
        timeentrada = time.strftime("%H:%M:%S")
        dateentrada = time.strftime("%Y.%m.%d")
        counts1 += 1
        variable1 += 1
        print ("ENTRADA RAMPA 1")
        print (counts1)
   if(variable1==1):
        print ("Entrada Contada")
        coneccionentrada()
        variable1 += 1
# Salida de Auto Habitacion  1 #
   if (input == GPIO.HIGH) and (variable1==2):
        datesalida = time.strftime("%Y.%m.%d")
        timesalida = time.strftime("%H:%M:%S")
        coneccionsalida()
        variable1 = 0
  • mconners
    0 mconners over 11 years ago
    This may seem obvious, but in your while loop compare the time and reset counts to zero if it falls within a range.
    What is the issue that you are having? Do you need help with the logic? Or the syntax?
    Mike
  • giusepperamos
    0 giusepperamos over 11 years ago in reply to mconners
    I need the variable counts1 returns to 0 at 7:00 am.
    I dot know here to put the time comparison .... because if the script is in the line "wait for an edge" it will never get back to 0 value.
  • fvan
    0 fvan over 11 years ago in reply to giusepperamos
    Perhaps too brutal, but I'll propose it anyway:
    You could use cron to kill and restart the script at 7am every day. Won't matter in which state the script is.
    Frederick
  • mconners
    0 mconners over 11 years ago in reply to giusepperamos
    Maybe take a look at
    https://docs.python.org/2/library/signal.html#signal.setitimer
    Or google python timer interrupts.
    You should be able to accomplish what you need. Or as Frederick says, you could always reset it externally with cron.
    You wouldn't even need to kill it fully, you could kill it with a signal (like kill -1) and look for the signal in your program that way you could handle it gracefully.
    Mike
