Raspberry Pi Forum Model B+ analogue video out
  • Subscribers 685 subscribers
  • Views 632 views
gopishrk
gopishrk over 11 years ago
How to take out RCA equivalent video out from Raspberry pi Model B+
  • fvan
    0 fvan over 11 years ago
    you'll need a splitter cable like the one below:
    Be careful when ordering one, that the order of the rings on the cable match with the order of the Pi.
    Frederick
  • mahjongg
    0 mahjongg over 11 years ago
    You can use any cable that uses the second ring for GND.
    The correct order from sleeve to tip is:
    Video, GND, Right audio, Left Audio.
    so called "camcoder cables" have Video and Right audio swapped, but can be used by swapping the yellow and red RCA plugs.
    iPod and Zune A/V cables are useable, but have left and right audio swapped (swap red and with RCA plugs to correct).
  • gopishrk
    0 gopishrk over 11 years ago
    Hi All,
         Thanks for your reply. I bought one camcoder cable and its working, but it is giving only monochrome output while operaing with xbmc but with NOOBS primary GUI it is giving coloured picure, can anyone suggest anything
    Regards
    Gopish
    0 Former Member over 11 years ago in reply to mahjongg
    I tried this solution with a Panasonic camcorder cable with the combination red phono, ground, yellow phono, white phono. Swapping red for yellow did not work and no signal came to the screen. Any ideas?  Here is the cable:
    Nikkai Connect! Camcorder Cable - "Panasonic" 1.5m | Maplin
    0 Former Member over 11 years ago in reply to Former Member
    I also tried a cable with the GND as the second band with no succesS (tried swapping the yellow and red). Any ideas?
    Nikkai Connect! Camcorder Cable - "Sony" 1.5m | Maplin
