Raspberry Pi Forum can not stopp script, when piface interrupt is enabled
  • Subscribers 704 subscribers
  • Views 820 views
  • interrupts
  • piface
Hi there,
for my raspberrypi /piface combo I have an interrupt handler defined.
This is the code used:
class Demonstrator(object):
    pdf = None
    listener = None
    def __init__(self, setting):
        pifacedigitalio.init()
        self.pfd = pifacedigitalio.PiFaceDigital()
        self.activate_eventhandler()
    def activate_eventhandler(self, port=0):
            self.listener = pifacedigitalio.InputEventListener(self.pfd)
            self.listener.register(port, pifacedigitalio.IODIR_BOTH, self.setInput_eventhandler)
            self.listener.activate()
Now as soon as activate_eventhandler is called, I can not stop the script from the console anymor.
I have to kill it by using
kill -9 PID
is there a way to handle this more gracefully?
thanks
robert
    Not sure if this could be the cause, but in the first line you assign a value to 'pdf' then later refer to 'pfd' ... typo?
    Thanks Ian for pointing this out.
    unfortunately this does not make any difference.
    Any more Ideas how I can garuantee that an activated interrupt listener is deactivated before shutting down?
    thanks again
    robert
  • mconners
    0 mconners over 12 years ago in reply to e14 Contributor
    Perhaps you need to add another handler for SIGINT (ctrl-c)
    look here for an example. control - How do I capture SIGINT in Python? - Stack Overflow
    Mike
  • plmsherman
    0 plmsherman over 12 years ago
    You need to use a Python feature to disable your interrupt handlers. Add the following code to your program and the problem will be solved. The atexit.register line of code should be located immediately after activation the listeners. If you interrupt your program with a Ctrl-c, Python will let you know that a keyboard interrupt was received. Do a second Ctrl-c and the program will terminate.
    Phil
    import atexit
    def killListeners()
      listener1.deactivate()
      listener2.deactivate()
      return
    atexit.register(killListeners)
