Raspberry Pi Forum Raspberry Pi B+
  • Replies 8 replies
  • Subscribers 705 subscribers
  • Views 1159 views
  • rbi
  • connectivity
  • connecting
Raspberry Pi B+
I have bought rbi + model from amazon ...coneecting with sd card provided , hdmi cable and usb power supply but only the red led is glowing and nothing to display . I am connecting rbi through a laptop .
  • dwinhold
    0 dwinhold over 12 years ago
    I had a simular issue and found any micro sd card under 16gb didn't work. There was no information anywhere that said this. Once I used a 16gb it ran like i thought it would. You could give that a try.
    Good luck
  • crosseyejack
    0 crosseyejack over 12 years ago in reply to dwinhold
    I'm using 8gb Kingston Micro SD cards on my Raspberry Pi Model B+'s and they are working just fine.
    anoopmishra Did the package advertise that the SD Card came setup?
  • skipf
    0 skipf over 12 years ago
    I don't think the B+ comes with a BOOT disk. You'll have to compile one yourself.
    All the software is ALSO available on-line, too. I prefer Raspberian.
    0 e14 Contributor over 12 years ago in reply to crosseyejack
    I have sandisk from Amazon ....... Also it was already filled with noobs then I used newer from website download link but it didn't work !!!
    0 e14 Contributor over 12 years ago in reply to skipf
    Could you tell me a single s/w like raspbarien installing procedure .................... not noobs
  • skipf
    0 skipf over 12 years ago in reply to e14 Contributor
    This is what I used...:
    http://downloads.raspberrypi.org/raspbian_latest
  • crosseyejack
    0 crosseyejack over 12 years ago in reply to e14 Contributor
    Goto http://www.raspberrypi.org/downloads/ and down raspbian
    Unzip the downloaded zip file to extract the 2014-06-20-wheezy-raspbian.img to somewhere you can find it
    If you are using windows on your main machine follow this guide - http://www.raspberrypi.org/documentation/installation/installing-images/windows.md
    If you are running mac on your main machine follow this guide - http://www.raspberrypi.org/documentation/installation/installing-images/mac.md
    if you are running linux on your main machine follow this guide - http://www.raspberrypi.org/documentation/installation/installing-images/linux.md
  • crosseyejack
    0 crosseyejack over 12 years ago in reply to skipf
    Well the Pi Genernally doesn't include a SD card but places like Farnell do offer pre-installed SD cards.
    As for the image, the Model B+ runs just like the B/A models. so once the card is imaged there is a BOOT partition on the SD card as this is what the SoC loads the kernel from.
