Raspberry Pi Forum where are the source patch of the kernel 3.12.x ?
  • Replies 8 replies
  • Answers 2 answers
  • Subscribers 706 subscribers
  • Views 1123 views
  • wolfson
  • audio
  • drivers
  • kernel
  • raspeberry_pi_accessories
  • card
I'm on pidora, I should like to compile the kernel with the driver of the wolfson audio card but I don't find the patch for the kernel 3.12, I finded just for the 3.10.
Anybody knows where they are ?
    AFAIK:
    Repo:
    https://github.com/manish-wolfsonmicro/linux
    Thread where I got the info from:
    https://github.com/raspberrypi/linux/pull/672
    Thank you,
    Netherless I see it is the entire kernel source in the git repo with the driver of wolfson and probably many else stuff.
    I would like to have just a patch to add to the kernel source  that i have already mainly I'm not used with git.
    Hi Noel,
    I used the instructions here: https://blog.georgmill.de/2014/04/29/compile-wolfson-audio-card-driver-for-kernel-3-12-y-a-new-try/
    Hope this helps.
  • hystrix
    0 hystrix over 12 years ago in reply to e14 Contributor
    Can someone please explain this step in the "3.12.y A New Try" instructions:
    "and copy to root of the Raspberry Pi".....
    Copy which files/folders?  And how exactly?
    Many thanks.
    0 e14 Contributor over 12 years ago in reply to hystrix
    @ a d :
    when you extract the sentence from the context this makes no sense.
    the fully intructions of 3.12.y A New Try are :
    mkdir kernelAndFirmware_wolfson_r
    tar -xvjf kernelAndFirmware_wolfson_rt.tar.bz2 -C kernelAndFirmware_wolfson_rt
    and copy to root of the Raspberry pi.
    So I guess , you extract with tar command the files/folders in the dir KernelAndFirmware_wolson_rt , then you need to copy these extracted files/folder in root directory
    so the command recursive copy is : cp -r  (source) (destination)  ; then you take all the files in wolfsonAnd... dir (the source) : WolsonAnd.../*  ; then you say the root dir : / (the destination) .At the end you have this command to type :
    # cp -r KernelAndFirmware_wolson_rt/*  /  ;
    Sorry everyone, I should expand; - I did it "the hard way" (instructions at the bottom) by compiling the entire kernel etc.
    I needed to do this because I also had a non-standard wifi USB dongle that needed drivers compiled.
    It takes longer (14 hours) but it does work.
    Good news.
    I'm going to try too.
    Hello everybody,
    I also try to compile the wolfson audio card for the kernel 3.12. I have a question about the instructions above. Is: sudo cp -r KernelAndFirmware_wolson_rt/*  /  the right command to copy the datas into the root-register? Where exactly can I find the command kernel=kernel.img in the /boot/config.txt. It's very urgent for my project. I hope someone can help me! Sorry I'm a beginner;)
