Raspberry Pi Forum can't start the raspberry for first time?
  • Subscribers 703 subscribers
  • Views 755 views
Dear Members,
I have problem on first time boot raspberry where I had pluged in the keyboar, mouse and HDMI to VGA cable for display.
Nothing display on my screen after I turn on my power supply from stontronics ltd.
anyone can guide me. For your information, I brought the B+ with microSC pre loaded noobs
thanks
mark
    0 shabaz over 11 years ago
    Hi Mark,
    The issue may be the HDMI to VGA cable. There is a verified peripherals guide that can be consulted.
    The LED indicators can also provide some help.
    There is also a troubleshooting guide.
    Ok i have had the same problem so i know how you feel!
    right here is how you get it working.
    1) plug your micro sd card into your computer and open it up.
    2) you should see the config.txt click on it and open it up.
    3) uncomment the line hdmi_safe=1    (so basically take away the hash key on each side of  hdmi_safe=1)
    Hope this helps.
  • johnbeetem
    0 johnbeetem over 11 years ago in reply to shabaz
    Mark: the Troubleshooting Guide is the best starting point, starting with the "Power/Start-Up" section: http://elinux.org/R-Pi_Troubleshooting#Power_.2F_Start-up. In particular look at the LEDs to see how far RasPi got in the boot process.
    Many start-up problems are due to iffy power (http://elinux.org/R-Pi_Troubleshooting#Troubleshooting_power_problems) which is often caused by a substandard Micro USB cable (http://elinux.org/On_the_RPi_usb_power_cable, http://www.element14.com/community/community/raspberry-pi/blog/2014/03/07/raspberry-pi-usb-power-cables-crashing-and-other-problems).
    0 e14 Contributor over 11 years ago in reply to johnbeetem
    John;
    Finally I managed to turned on my raspberry pi cause my failure on HDMI to VGA converter.
    Thanks for your advice and now i do understand the function of Green and Red LED.
    Jacob,
    thanks for sharing
    my problem was cause by HDMI to VGA converter issue.
    0 e14 Contributor over 11 years ago in reply to shabaz
    SHabaz,
    you are right cause by HDMI to VGA cable .
    now I am able use the pi
    thanks
