Raspberry Pi Forum Dancing traffic light
  • Answers 2 answers
  • Subscribers 673 subscribers
  • Views 606 views
  • raspberry-pi
  • matlab
  • simulink
anujaapte
anujaapte over 11 years ago
Madhu here! For this week’s post I will discuss a video that I came across on Youtube. I assume everyone would agree that this is a cool concept, but how did they implement this?
I will present my thoughts here and it would be great to discuss alternative approaches with all of you – My hunch is that the booth is equipped either with a video recorder or some sort of a motion detector.
The video recorder route can be relatively simple with a raspberry pi because of its processing power. The background is of a certain color, which means that there has to be a unique RGB weight that can be used to extract the person accurately. Once you have a sequence of images in which you know where the person is, then turning ON and OFF the appropriate LEDs at certain frame rate is not a hard problem. Implementing this in real-time would be much more challenging which makes me believe that they went with the second guess – the motion detector.
Motion sensors can detect joints easily and would be ideal for this application, but they do not work effectively outdoors (which is probably why they chose an indoor booth).
For more inspiration check out this video created by my colleague Bharath that teaches MATLAB enthusiasts how to implement similar ideas using a Kinect sensor (in Real-time).
  • Robert Peter Oakes
    0 Robert Peter Oakes over 11 years ago
    I love the concept as a safety add-on and it looks cool too, as for the implementation, a very low resolution camera (64*64)  is all that is needed and only Black and white, a simple comparator to convert to an on or off for the relevant LED. There is no need for colour as the lower display always uses green and the upper RED, to the system it is all black and white with NO shades in-between
    as such you would not even technically need a micro-controller but then where is the fun in that
    even an Arduino UNO would be fast enough to capture the relatively low frequency / resolution video and convert it in real time to the LED output stream
    Thats my thought
    Peter
  • Problemchild
    0 Problemchild over 11 years ago
    More likely a low resolution camera which has a threshold applied to it then those bits streamed into the LED array.
    0 Robert Peter Oakes over 11 years ago in reply to Problemchild
    Snap image
  • Problemchild
    0 Problemchild over 11 years ago in reply to Problemchild
    Indeed Peter the simplest is often the best couldn't think of why you would need to make it complicated!
  • Problemchild
    Just storing some footage 64x64 and playing it back would make for some interesting Redlights maybe even have competions to "collect" all the variations about the city image
