Raspberry Pi Forum Accessories for A+ Model Raspberry Pi
  • Replies 8 replies
  • Answers 2 answers
  • Subscribers 675 subscribers
  • Views 1057 views
  • a+
  • raspberry-pi
I just got a simple A+ model Raspberry Pi, no extra stuff with it.
What accessories would you recommend purchasing? I can't seem to find any A+ starter kits, if you know of any I'd be interested but just generally what accessories would you recommend?
I would like to do stuff with the Pi involving transmitting radio signals etc, robotics, and general programs, if that helps.
Charles
    Essentials and some extras for a good start with the A+;
    Power supply (microB USB) + SD Card + HDMI cable + keyboard/mouse = ESSENTIAL
    A good case
    A compatible out-of-the-box WiFi dongle (you will now need a hub if not using SSH...)
    Breadboard, male-female wires, etc
    There are many kits available around the net as for robotics projects.
    You can try PiRadio for transmitting radio signals using just a solid core wire as an antenna. I tried it, it works fine and is fun.
  • Problemchild
    0 Problemchild over 11 years ago
    WIFI Dongle on the USB and stick the controls for the robot on the GPIO.
    No need for the Keyboard /mouse because then you'll need a hub and if this Robot is mobile it will be dragging the keyboard with it image
    Instead of that use SSH or similar to send commands to the A+/Bot   also if you can do not use the GUI as this will same you tons of memory and make stuff run miles faster!
  • Problemchild
    Are you going to use that little LCD monitor that you mentioned on a previous post ... If you are then a 12 V battery will be handy and use a switch mode regulator to  get the 5V for the PI!
    0 Former Member over 11 years ago in reply to Former Member
    I know this is very lazy of me but I don't want to get it wrong -
    Do you have any links to those essential parts, and also a good kit for making a robot, and the breadboard/wires?
    If you know a good single place to get all this as well, it'd be useful.
  • Problemchild
    0 Problemchild over 11 years ago in reply to Former Member
    CPC /E14 them selves have pretty much everything you want. They might be more than many other suppliers but if it's a matter of one shop then they do well
  • Problemchild
    0 Problemchild over 11 years ago in reply to Problemchild
    Try here as a starting point for ideas:
    http://cpc.farnell.com/jsp/bespoke/bespoke7.jsp?bespokepage=cpc/en_CC/makerspace/raspberrypi.html&isRedirect=true
    0 Former Member over 11 years ago in reply to Problemchild
    Most of the kits and accessories seem to say they're for B+, will they still work for an A+ model? And before I buy the stuff, would you be happy to check what I've chosen?
  • Problemchild
    Yeah the only difference between them all is  the cut outs made to  make sure that the  extra connectors on the B+ aren't obscured. Some need to use the 40 pin connector but you have that to, so no problem there. Because you have so many  fewer connectors I think you can use almost any of the B/B+  peripherals especially if you are willing to use a 4 port extender and or a rubber foot to support a board. I can check the items ..Should be no problems !
