Raspberry Pi Forum How do I set up "Recording in mono" use-case.
  • Subscribers 705 subscribers
  • Views 676 views
  • raspeberry_pi_accessories
jcjc
jcjc over 11 years ago
Record_from_DMIC.sh says:
# The following command should be used to test
# arecord -Dhw:sndrpiwsp -r 44100 -c 2 -f S32_LE <file>
And it does.  Lovely.  However how do I record only a single channel?   "-c 1" doesn't work:
pi@raspberrypi ~ $ arecord -Dhw:sndrpiwsp -r 44100 -c 1 -f S32_LE out.wav
Recording WAVE 'out.wav' : Signed 32 bit Little Endian, Rate 44100 Hz, Mono
arecord: set_params:1087: Channels count non available
I did try naively commenting out bits of Record_from_DMIC.sh to eliminate everything about the "R" channel, but that didn't work.
Lastly - can someone confirm that this is the best arena for me to learn about this device? (the raspberry-pi B+ model).
Thanks.
James.
    You can't record just one channel directly from the card. It will insist on two channels.
    That can be worked around by using my .asoundrc file, described here.
    Ragnar
    Are you aware of any python scripts working with pyaudio and the wolfson card?
