Raspberry Pi Forum What is the actual clock speed of the pic?
  • Subscribers 706 subscribers
  • Views 1952 views
  • raspeberry_pi_accessories
What is the actual clock speed of the pic?  It is rated at 48 MHz, but
a 8 MHz crystal is used.
Nick
    0 michaelkellett over 11 years ago
    It's probably running at 48MHz (if you are using the standard Microchip code) but can be programmed in software. Almost all modern micros use a PLL (google it) to multiply the crystal (or internal oscillator ) frequency up to a suitable speed for the core. This is because high frequency external oscillators use lots of power and can have many other problems too.
  • smartie1242
    0 smartie1242 over 11 years ago in reply to michaelkellett
    Where did you learn that stuff?
    0 michaelkellett over 11 years ago in reply to smartie1242
    Approximately 40 years as an electronic engineer - you either learn stuff or find something else to do.
    It's much easier now to get information than it was when I started. Follow newsgroups, join a few forums like E14, read on-line magazines, design your own stuff (and do it properly, start with the data sheets and the app notes from the chip makers, not with a spoon-feed from AdaFruit or similar).
  • smartie1242
    Cool because i'm just starting and have almost no experience
    0 mcb1 over 11 years ago in reply to smartie1242
    AND internet search engines are your friend.
    I always find that doing your own research leads to better understanding and better retention of the information.
    You may also discover some other very interesting/fun uses or applications while searching.
