Raspberry Pi Forum Cirrus Logic card as SPDIF DAC
  • Subscribers 705 subscribers
  • Views 1270 views
  • audio
  • cirrus
  • dac
  • raspeberry_pi_accessories
  • spdif
timg73
timg73 over 11 years ago
Hello, Can the Cirrus Logic audio card take an SPDIF input from an external source and play it on the analogue outputs?  If so, is there likely to be much latency?  Does the audio data have to pass through the Raspberry Pi or can this be handled by the card's hardware? Thanks,
  • timg73
    0 timg73 over 11 years ago
    I'll answer my own question: yes, it can.  The mixing is handled in hardware, and the latency is about 300us.
    BTW if anybody from Cirrus Logic is listening, a bit more documentation would be appreciated.  There's a lot going on in this little audio chip and there are literally hundreds of registers and mixers accessible through the Linux driver.  Parts can be figured out by reading the WM5102 datasheet, but the names don't always correspond.
  • gkzsolt
    0 gkzsolt over 11 years ago in reply to timg73
    Hi Tim,
    Nice you figured it out. Can you tell how did you do that? I'd like to do the same thing. Also, to play the samples got from Line In, "quasi in sync", without going through the computer. Would that be possible? I read about some "copy plugin", but I am not good at ALSA. (I definitely would not do arecord ... | aplay ... at this point.)
    Any help, also from the Cirrus engineers would be much appreciated. Thanks,
  • gkzsolt
    0 gkzsolt over 11 years ago in reply to gkzsolt
    I (also) solved my problem. It's not at all difficult, and the card/driver gives you many possibilities. Passing through the WM5102 datasheet gives you a feeling about its immense set of features. It is really, really impressive. Thanks for this, Wolfson.
  • timg73
    0 timg73 over 11 years ago in reply to gkzsolt
    It's certainly an impressive chip.  As well as the datasheet the output of 'amixer' gives a lot of useful clues.
    So how did you do it?
  • 0d0a
    0 0d0a over 9 years ago in reply to e14 Contributor
    Yeah , pls describe how you did this? kernel 4???
