Raspberry Pi Forum Can you setup a raspberry pi for the first time with just a laptop?
  • Replies 7 replies
  • Answers 2 answers
  • Subscribers 687 subscribers
  • Views 813 views
I am just wondering.
  • royleith
    0 royleith over 11 years ago
    Yes you can.
    Any laptop and any operating system.
    Method 2:
    Get a card preloaded with NOOBs and just plug Raspi in and turn on.
    Is there something more behind your question?
    0 Former Member over 11 years ago in reply to royleith
    Thank you. I asked so I could make a list of things to get along with the raspberry pi itself.
  • gadget.iom
    0 gadget.iom over 11 years ago in reply to Former Member
    From reading the NOOBS setup page (http://www.raspberrypi.org/help/noobs-setup/) it seems you will also need a keyboard, monitor, etc.
  • packetgeek
    0 packetgeek over 11 years ago in reply to gadget.iom
    I set my Pi's up without keyboard/monitor/mouse.  After writing the image to the SD card, and before I eject it, I edit /etc/network/interfaces to that it uses a static IP (makes it easy to find).
    Also, on first boot, I wait about two minutes and then power cycle the Pi.  This is because there's a config script that runs during the first boot.  I then connect to the Pi via SSH and run "raspi-config".  Everything works normally after that.
    I realize that there's probably a script to edit to avoid the first boot issue but I've not had the time to research it and I haven't had any issues with my method (so far).
    - Tim
  • gadget.iom
    0 gadget.iom over 11 years ago in reply to packetgeek
    I've never used NOOBS (prefer Raspbian), but with references made to NOOBS I looked around a bit online and couldn't find much information about setting that up in a headless configuration.
  • clem57
    0 clem57 over 11 years ago in reply to gadget.iom
    @gadget.iom
      Raspberry Pi could be used headless without ever adding keyboard, mouse, or monitor if after creating Rasbian sdcard you do the following on Linux:
    mkdir ~/sdcard
    sudo mount /dev/sdb ~/sdcard
    mv ~/sdcard/boot_enable_ssh.rc ~/sdcard/boot/boot.rc
    umount ~/sdcard
    Unfortunately Windows does not natively handle ext4 type files so hard to do..image@packetgeek I think this also would eliminate the wait 2 minutes/reboot scenario.
    Clem
    So Noobs is ext can you format it to FAT32 to get windows to recognize it?
